SES light comes on flashing, then disappears by itself an hour later...
Old Mar 7, 2011 | 07:04 AM
djkevinnn's Avatar
I got my first SES light since owning the car (approx 6 months now) I went to start it up in the morning and the motor was running roughly, so I decided to go around the block to make sure everything was okay. Then, all of a sudden while driving, after some weird jerks, the SES light just starts flashing over and over, then eventually just stayed on. I got the codes read and got 2 counts of random cylinder misfire and a power steering sensor failure. Then, after driving around 5 miles, I started the car up again, and it was just gone.......
Should I look into this more? It's more than strange
Old Mar 7, 2011 | 07:31 AM
Rochester's Avatar
Sure does read like one of your coilpacks is starting to fail.
Old Mar 7, 2011 | 09:42 AM
nismopc's Avatar
I've had the same thing happen 3-4 times randomly now ever since I replaced valve covers and new plugs. I am running @ 160k+ miles on the coils/wires.
I'll just drive until the coil(s) actually goes out, if this is in fact the issue.
Old Mar 7, 2011 | 09:48 AM
Rochester's Avatar
If a coil pack isn't functioning, that means un-combusted fuel is getting blown out the valve and likely burning as it goes through the heated elements in your catalytic converter, which can cause your cat to overheat and clog.
Or so I've been told. I'm no mechanic.
However, ignoring a problem is a valid option too.
Old Mar 7, 2011 | 12:57 PM
nismopc's Avatar
I'm quite good at that...
...But, I still have not received any misfire codes.
Only AIV solenoid (ever since block of plate) and secondary O2 sensors (after my dual O2 sim went and took a crap).
Old Mar 7, 2011 | 01:13 PM
phatboislim's Avatar
i agree w/ Rochester, sounds like a failing coilpack...which cylinder did it say is misfiring?
Old Mar 10, 2011 | 06:24 AM
djkevinnn's Avatar
I got 2 counts of random cylinder misfire, so I have no idea.
Old Mar 10, 2011 | 06:26 AM
djkevinnn's Avatar
Thanks! I'm not sure what's happening at the moment, I'm just waiting for another occurrence. Then I'll start looking into replacing the coil packs and plugs. 80k miles is coming up, so maintenance time is soon near.
did you not get the code # when you pulled the codes
Old Mar 10, 2011 | 06:27 AM
djkevinnn's Avatar
I have them, I left the paper in the car, I'll get them later today.
Old Mar 10, 2011 | 06:38 AM
Rochester's Avatar
Coil packs cost between $80 - $110 each, depending on how you purchase them. You have six, which means $480 to $660 in parts. Figure another $50 for a new 6.0 gen rear valve cover & gasket, and another $50 for a set of plugs, and then if you go to a mechanic and incur 2-3 hours labor...
My point is, you could easily spend a cool $1000 with what seems like a simple maintenance item.
Or you could identify the errant coil pack, replace it (with a 50:50 chance it's in the front bank), and walk away.
Old Mar 10, 2011 | 06:41 AM
djkevinnn's Avatar
Yeah, I'm going try to find the 1 or 2 that are faulty and change out the plugs. Being a poor college student who is fairly competent with his hands, I'll do the work myself.
Old Mar 10, 2011 | 06:47 AM
NmexMAX's Avatar
dot dot dot ...
Flashing = multi cyl. misfire ...
Old Mar 10, 2011 | 10:52 AM
djkevinnn's Avatar
Codes were P0300 and P0550
Old Mar 10, 2011 | 11:48 AM
Scottwax's Avatar
That's Mr. Detail to you
Had that happen after my car sat a couple weeks after it was hit and totaled. I had been starting it to keep the battery charged since when the adjusters do the estimate, they need to see what the mileage is. Anyway, I started it up and it was running really rough. Got a misfire code and a power steering sensor code. Cleared the codes, restarted the car and it idled and revved fine after that. Not like it mattered much, wasn't going anywhere with how badly damaged the car was.
Old Mar 10, 2011 | 08:04 PM
L36's Avatar
L36
It might ruin your cat, get it fixed and pay for the coil rather than pay for the coil and cat later.
captchaos
Mar 15, 2016 12:18 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
intimidator
Sep 5, 2015 07:23 PM
