Would someone clarify to my about ECU update ?
Hi
I was wondering : does any Maxima 5.5 gen ECU can be updated to the latest ECU software (the sofwatre in the ECU of the very last Maxima 2003 made) or not ? and what the factors that determine this ? VIN ? or what ?
I was thinking that it's like a PC hardware in which you can always have an updated software(driver).....
thanks
thanks
Hi
thanks
thanks
That said, I agree with NmexMAX. Cars are not computers, the software in the ECU besides being monumentally simpler compared to that which is written for a computer is also thoroughly more tested before release.
In the case of a computer a bad driver causes the piece of hardware it ties to to not function. Presumably all Maximas function from the factory so the precludes the possibility of a faulty firmware. In the event there were one it would no doubt result in a recall as that would probably mean the car was running way out of fuel spec at points. Which is the last point, I think that is mostly what the ECU controls is fuel timing, again presumably, that is not something Nissan tinkers with too much from firmware to firmware if they even revise their firmware regularly.
From a simple search here , I heard that there were an ECU update for some maxima 5.5gen with slow acceleration issue back in 2004 or 2005 I'm not very sure...And I was thinkning that probably the previous owner didn't know about this
You can reset your RAM yourself.
IIRC:
ROM (Read Only Memory) holds all the fuel trim plots, and baselines for everthing, it cannot be altered, it is only read.
EEPROM(Electrically Erasable Programable Read Only Memory) Holds the 'self learning' stuff.
And then, RAM, which is erased as soon as your ECU battery dies. Stuff like engine codes, problems, anything relevant to the ongoing function of the vehicle.
Oh and Nissan won't tell you there is a TSB when they do a VIN search. They VIN search for RECALLS. It's very difficult most times to get a dealership to look up a TSB, let alone even admit there is a TSB database they can access.
Your best bet is to call NissanUSA, and get a print out from them, or the specific TSB number/information, then take it to the dealer, and if they still give you a hard time, call NissanUSA again and report it.
^No, if you pay, they will gladly do it. Big TSB's are usually, but not always, covered by NISSAN (not the dealer, NissanUSA). The problem is, the dealer doesn't want that hassle, and they only get paid what it costs them, they don't normally make any money off it, so they're not interested in doing it, unless the 'big head' tells them to.
There is also usually a time limit from the issuance date of the TSB that Nissan will cover the repair, so I'd expect that you'll be paying anyways. It never hurts to call NissanUSA and see if you can find out. I suggest finding the TSB online before you bother though.
Yeah, the hesitation thing is starting to annoy me. It kills the feeling of engine responsiveness and driving at speeds greater than ~3200 RPM is one heck of a lousy solution.
There's no way I could get a dealer to flash the ECM for free. What do they charge to flash it? Surely it takes five minutes or fewer, right? Five minutes in dealer time is... $80? My logic was get the reflash, then walk over to the tech and ask him to do the 17 degree timing advance while it's hooked up.
Mine is a reasonably early '02 car (09/01 build date) so I don't know if mine requires a new MAF along with the reflash.
Mine is earlier one,July 2001....Replaced the MAF already with 2k1 MAF (with the conversion trick) , but thinking about hitting the dealer for the ECU update..But I think I will have a hard time convincing them to overlook my new MAF and only do the update ...... I don't expect them to be smart enough to manipulate things...
P.S.
Another question please : is each TSB requiring ECU flash has different version OR they will all end up with putting the latest software ?
I really would like to know how the dealership interfaces with the ECU for programming and all of what is involved. I've been doing computers for a long time and I've never heard of any EPROM taking an hour or a half hour or 15 minutes even.
So my questions:
1. What interface does dealership use to access ECU? OBDII? Does the ECU get pulled and plugged into a special machine?
2. What Operating System is on that computer which interfaces with ECU? Win 7/Vis? XP? Win9x? DOS? Unix/Linux?
3. How does a Nissan dealership get their ROM files for flashing ECUs with?
Correct once flashed an ECU is not subject to corruption save for rare circumstances involving hardware damage (which flashing would not fix). You are probably also correct about the ECU having some sort of RAM and battery which would explain why just pulling the battery for 2 seconds won't clear the ECU but leaving it unplugged overnight will.
So my questions:
'Data' is very unlikely to get corrupted in the ECU. Unles I'm mistaken, most of the base plots are ROM. Flashing/Replotting/Upgrading would only affect EEPROM, and the dealer has to do that.
IIRC:
IIRC:
So my questions:
So my questions:
Anyways, Nissan uses 'CONSULT', it is their own system, and is specifically designed for their software/ECU's. You cannot interface with a Nissan ECU for programming purposes without the "CONSULT" device.
Time wise, no it takes hardly any time at all, but Nissan charges $80 average just to plug it in.
Then they charge by the hour for diagnostics, and they usually charge more for electrical diagnostics. There is also usually a minimum fee (1/2 hour or something).
Either way, you'll be hard pressed to get in/out under $120, even if it only takes them 5 mins (they'll likely make you wait so it seems like it took longer).
USB Nissan Consult cable
It says it can grab a ROM dump but nothing about reprogramming/flashing. I wish the ECU didn't have to actually be installed though. I would feel much more comfortable hacking an ECU if it wasn't attached to an engine it could destroy lol.
An HOUR!? Yiiiiiikes, the ECU must be larger than the only EEPROM things I've messed with (namely, 4 to 64MB N64 cartridges.), or they made you sit on your hands to trick you into thinking you were paying for legitimate work.
litch
123
01-04-2024 07:01 PM
mkaresh
03-12-2018 06:48 PM
