TRANNY OUT AGAIN.... SMH.. STEP IN
Old Mar 18, 2011 | 10:06 PM
BLACKKILA.GTR's Avatar
soo heading to work this morning my tranmission decides it want to give out on me !!!!!f()ck!!!!!! need to get another one quik, used is cool as long as it doesnt have crazy *** miles.. just looking for some insight on where to get one @ for a good deal or if you have one for sale that works too... need it asap... thanks
Old Mar 18, 2011 | 10:20 PM
tookrzy4u192's Avatar
sorry to hear that ma, have you tried "car-part.com"?
Old Mar 18, 2011 | 10:31 PM
yo ur the man son that is deff helping out!!!!!!!!!!!!!! thanks
just wondering even though im pretty sure.. the i35 tranny will work for a maxima correct.. any......
Old Mar 19, 2011 | 05:37 AM
Sneaky Green's Avatar
Yes Sir! My car is in the shop for new internals for my transmission now. As this was one of my options or at least I asked my mechanic. Even on car parts when you put 03 Maxima in 2002-2004 I35 trannies pop up. Go for it Homie
Old Mar 19, 2011 | 06:06 AM
Grand_hustle17's Avatar
Car-part.com most of em go warranties also.... or you can do like me... 6spd swap lol
Old Mar 19, 2011 | 05:54 PM
phatboislim's Avatar
nissan trannies ftl
gl with your tranny find man..just waiting for when ima have to replace mine again
Old Mar 20, 2011 | 05:22 PM
datdude20's Avatar
get a tranny cooler
Old Mar 22, 2011 | 09:03 AM
Originally Posted by datdude20
get a tranny cooler
i have one.....lol....
but i have a question as far as fluid wat kind should i get.. should i get nissan tranny fluid or is there a substitute? getting the tranny fixed next week and dont know if the shop will use the right fluid....(they mostly do american cars)
or should i just trust them and the fluid they have??
need input fast please.. thanks
Old Mar 22, 2011 | 09:04 AM
i just got some Amsoil from one of the vendors on here...
Old Mar 22, 2011 | 09:09 AM
Shift_Nismo's Avatar
Amsoil
Old Mar 22, 2011 | 09:21 AM
amsoil is good?? i need 10 quarts right?> somebody got the link so i can buy some...??
Old Mar 22, 2011 | 09:24 AM
idk about 5th & 5.5 gens, but my 4th gen 5spd only needs 4.5qts. Here is a link:http://forums.maxima.org/group-deals...ubricants.html
Old Mar 23, 2011 | 08:51 AM
02AutoMax's Avatar
BLACKKILA.GTR before your tranny decided to shell out on you, did it have a delay at shifting between 1st and 2nd at WOT?
Mine will have a delay and stay around 6k for a sec or so before shifting into 2nd and wanted to know if that was a early sign of it about to die
Old Mar 23, 2011 | 11:20 AM
pkrainert's Avatar
02 automax, I had that problem and changed my Valve Body and now it is perfect.
Old Mar 23, 2011 | 11:39 AM
5 quarts are needed.
Old Apr 23, 2011 | 04:05 PM
SO it ended up not being the trans... instead some how my axel popped out... (i did change it out the day b4) neva had that issue b4... since the town im in is wack they didnt have any fluid for my car the had to use a fluid from napa and put an additive in to make it work..(????) i do have a case of the amsoil should i just have them change that fluid out cause im pretty sure they mixed it with my old fluid..smdh..
Old Apr 23, 2011 | 06:30 PM
OHH NOES's Avatar
6spd Swapped
That doesn't sound right, you shouldn't have to add an additive to make it work, change that fluid ASAP, they probably used garbage. If you have the Amsoil, get it changed. You have an auto right? If you do a drain and refill you will need 5-6 quarts, all 11 quarts don't come out. After 2 weeks I would drain/refill again to make sure you get as much of the old stuff out. Just make sure you use the right fluid.
Old Apr 23, 2011 | 06:37 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
exactly what he said. i ran into a problem with mine when they did my fluid exchange. was supposed to be a fill and refill, they did the suction. car died a week or so later. was noted that they added that crap fluid as well.
i stuck with the nismatic d, but im sure youll be alright with aftermarket I just didnt want to go with anything outside of what I knew worked.
Old Apr 23, 2011 | 08:53 PM
NAVY00MAXIMA's Avatar
http://http://www.autohausaz.com/sea...ans Filter Kit
AUTO TRANS FILTER KIT--^
I would stick to using OEM transmission fluid. Detergents in the others are not always compatible.
Old Apr 23, 2011 | 09:48 PM
Scottwax's Avatar
That's Mr. Detail to you
nissan trannies ftl
I had 194,595 on the original transmission in my 5.5 gen when it got totaled and it was shifting great. Nice pinkish red fluid, smelled fresh.
Old Apr 24, 2011 | 12:01 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Yep, I know a guy with 200k on his bone stock GLE.
How the motor hasn't blown up yet, I don't know (precats yikes!).
Old Apr 24, 2011 | 04:33 AM
i had 183k before mine went out. i'm sure there are others that can testify to my statement. GL to blackkilla on fixing the issue though. hope everything works out
Old Apr 24, 2011 | 11:53 AM
Bad *** Newb
Originally Posted by tomcat
Probably overkill but I change my fluid about every 20K miles. I was bit by too may auto failures early in my life.
Driven hard I think 30k intervals is a must. I have a MT, but I turned my fluid brown in 10k miles.
HOKUSMAX
Nov 13, 2017 04:34 AM
gigabyte
Jan 6, 2017 06:05 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
