02 Maxima clicking noise/screeching in reverse
Old May 25, 2011 | 06:27 AM
MintVQ35's Avatar
Symptom: After driving for 10+ minutes I get this clicking noise coming from the left front that increases/decreases with vehicle speed. When I put the car in reverse and start backing up the clicking turns into a loud screeching noise that I can make stop by hitting the brakes fairly hard. I have had the brakes apart multiple times to check for uneven wear/anything out of the ordinary and have cleaned the entire setup twice now, no change. Are these symptoms reminiscent of a bad cv or a bad wheel bearing? I do not get any other strange noises besides the clicking/screeching in reverse. Search provided nothing but results for screeching/clicking when applying the brakes which is not the case here.
Old May 25, 2011 | 11:16 AM
maxima 21's Avatar
examination
Jack up the car and leave the wheel on. If you can wiggle the wheel up, down, left, right, it is probably a wheel bearing. But if there is play that should lead you to the issue
spidgeon
Aug 18, 2015 05:46 AM
Trin1j23
Aug 12, 2015 08:31 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
MikesChevelle
Aug 9, 2015 11:50 AM
Jcof88
Aug 3, 2015 10:43 PM
