Motor mounts inquires ....
Old Jun 4, 2011 | 11:30 AM
mahanddeem's Avatar
Dear orgers,
Sorry if this was asked many times , but the time frame does make difference in parts availability and accumulated experience...
So ..... I will have the manual transmission mount (front LH) replaced with OEM one from courtesy nissan......Now for the rest of them , I do feel vibrations with speed sharp turns and so , which makes me believe that mounts may need some love and cash.... The one infront of the radiator seems to be widened a lil bit,the passenger side mount rubber is cracked inside , although they look clean from the outside , car now sits at 123xxx miles (I don't know what was done before the 118k miles)
1.Is it a better idea to have the mounts out and replace the rubber with ES bushings or order new ones from DaveB or courtesy nissan ? would the ES bushings do a good job like the new OEM replacement ?
2.Would you bother with the front and rear first or do the sides first ? I heard some say the side mounts don't really go bad
thanks
Old Jun 4, 2011 | 01:07 PM
00Lightsout's Avatar
don't bother putting the OEM replacements in...get the ES Polyurethane mounts! I just installed mine a 2 days ago...LOVE THEM!!
as far as the side mounts, replace both the driver side(trans mount) and the passeger side(timing side mount). It is best to replace all if they are all messed up. You can get some rather decent trans and timing mounts on Ebay or at your local shop. No need to stick with NISSAN parts for motor mounts b/c by now they are not covered by a patent anymore i believe, and soooo many places build and retail them.
You will actually SAVE $$ if you purchase the ES mounts, and install them yourself ...with enough patience and a decent set of tools you can do almost everything on your car yourself and save $$$$.
check my link above my sig for my most recent project with motor mounts and CV axle alignment for lowered Maxima's!! I just took a break from Fabricating the parts to check the ORG
Old Jun 4, 2011 | 01:55 PM
NmexMAX's Avatar
dot dot dot ...
I agree.
Also, you can try filling your side mounts with some stuff from 3M. Try searching it. I believe Cmax and sparks have both commented on it.
Old Jun 4, 2011 | 02:45 PM
nismopc's Avatar
I agree. 3M is a great alternative and easy to use except it takes a while to cure properly...
...good stuff!!!
Old Jun 4, 2011 | 04:31 PM
CMax03's Avatar
fill the sides with 3M Window weld and replace the front and rear with ES poly inserts.....
Old Jun 4, 2011 | 06:45 PM
mahanddeem's Avatar
So "aftermarket" mounts OR OEM mounts filled with ES inserts ? which will yield better results ? and what brand would you consider best ?
Old Jun 4, 2011 | 09:00 PM
nelledge's Avatar
"I'm just sayin'..."
...good stuff!!!
Quoted for emphasis.
Old Jun 5, 2011 | 01:04 AM
the ES mounts will ONLY fit inside the lower 2 motor mounts for a MANUAL trans....the auto trans is the wrong size.
then find the HOW TO thread for filling your side mounts with the proper material.
Old Jun 6, 2011 | 05:01 AM
Sterling's Avatar
http://www.amazon.com/s/ref=nb_sb_no...ngine%20mounts
I only need the passenger side (I have a 6spd)
Im looking at the site above and its misleading and hard to understand - I think theyre all for automatic unless I missed a number from 1-84 there -
I only need the passenger side and im confused as to when they say front and rear...
Thanks for your help
Old Jun 6, 2011 | 06:18 AM
TallTom's Avatar
your car is equippped with:
One Engine mount (located on pass fender)
Two Torque mounts ( below engine on front near radiator and rear near firewall)
One Trans mount (located on Drivers fender under intake piece)
The ES bushing are for the Torque mounts.
Old Jun 6, 2011 | 06:29 AM
Rochester's Avatar
The ES bushing are for the Torque mounts only for the MT.
Well done, Tom. Transverse engines really do make things like this confusing.
One clarification, but since Sterling has a 6MT, it's a moot point.
Old Jul 8, 2011 | 07:12 PM
pdtass's Avatar
I know this is not exactly related to your post
I know this is not exactly related to your post but I am not able to post a new thread unless I have 15 posts.
I just replaced my upper passenger side motor mount and it solved a clunking noise that occured when I went over bumps. If you try and replace this motor mount do not use the one available from Auto zone because the holes will not line up ( I have a 2002 SE AT). I purchased the Beck/Arnley from Rock Auto and it lined up perfectly. I did have to jack the motor up about an inch for everything to line up though. To support (adjust) the engine just place a piece of plywood or a 2x4 under the oil pan and use a floor jack.
I also had a rattle but that was the exaust heat shield that rusted loose.
Old Jul 15, 2011 | 05:56 PM
JagerBlunt's Avatar
I fill mounts with Polyurethane resin, either 80a or 94a hardness (your choice) for $75ea for a SOLID FILL,plus shipping WITH YOUR MOUNT they come out very well, $20 more and I'll strengthen the welds TIG welded not MIG welded and re-paint them. If you cant have a week of down time I can source you an aftermarket core and then fill it
Old Jul 16, 2011 | 05:34 AM
maxspeed96CT's Avatar
The original VQ...
I have a set of ES polly mounts for sale , 100$ and they are yours.
I havent had a chance to make a for sale thread yet. shot me a PM if you interested.
will fit 95-01 but i think 02-03 these mounts are the same aswell .
(sorry for the camera phone pic)
Old Jul 17, 2011 | 08:18 PM
CMax03's Avatar
Manual mounts fit 95-03 Maxima(s).........
Old Jul 21, 2011 | 02:40 AM
Camry343's Avatar
You have a PM.
Old Jul 21, 2011 | 06:30 AM
The original VQ...
My mounts are sold boys , srry. Can't edit the post on mobile view.
Old Jan 16, 2013 | 11:54 AM
duanesr's Avatar
I know this was an old post. Is changing the passenger mount as easy as it seems. Maybe 30 minutes? An i have heard that beck arnley is the way to go
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
