Gas filling up and overflows all the time?
Old Dec 26, 2001 | 07:43 PM
RussMaxManiac
Anyone else have this problem?! My 2k never had this issue but my 2k1 does. When I fill up and when it cuts off my filler, it overflows onto my damn paint with gas. I try to not let it do it, but it just happens. My paint is starting to degrade under the gas tank filler, its not shinny anymore. I might need to go get it professionally buffed, but I want to prevent this from happening... Any ideas?
Old Dec 26, 2001 | 08:15 PM
BioMaxDDS's Avatar
sorry not here!
Old Dec 26, 2001 | 08:19 PM
Ludacris's Avatar
My dad had that happen to him the other day! Hmm...it was the first time though. Mebbe I should wash it tomorrow
Old Dec 26, 2001 | 08:24 PM
ZIPPIN's Avatar
Mauja He Mauja
Re: Gas filling up and overflows all the time?
stick a surgical camera in there
Old Dec 26, 2001 | 08:31 PM
TPI Monte SS's Avatar
Russ, this happens all the time with my Monte. My advice is to keep a small rag in the trunk, or borrow one from the gas station. Put the nozzle in the filler neck, then fold the rag up and leave it on the lip underneath the pump handle. If any gas spills out, it'll hopefully be absorbed by the rag, and not into your paint.
Good luck!
SSeeya,
Steve Ragusa
North Jersey
www.bowtiepower.com
'00 Maxima SE and a resto-modded '85 Monte Carlo SS
Old Dec 26, 2001 | 09:36 PM
zman187's Avatar
You could do that or figure out how many gallons your tank holds then figure out how much gas you want to put in from there. I don't completly think its the car's fault though. Do you go to the same pump all the time, cause its the pump that detects when to stop, so maybe there is a problem with the pump? I don't know just a idea
Old Dec 27, 2001 | 12:26 AM
2001SE's Avatar
never happened to me, somethig with the pupm....or you are not pushing the nozzel all the way in
Old Dec 27, 2001 | 12:41 AM
NoHalo's Avatar
A few suggestions:
1) When setting the auto-pump leever, don't use the fastest setting.
2) Angle the nozzle differently --more to the right or left or even completely upside dowm.
3) Try a different gas station with a different pump manufacturer.
4) Pray to Allah, since the oil for the gas probably came from one of his countries...
Old Dec 27, 2001 | 05:42 AM
RussMaxManiac
Different pumps...I have tried many.
Old Dec 27, 2001 | 05:19 PM
MadNav's Avatar
I'm with RussMaxManiac .... Never had this problem with my Altima (traded in two months ago for a 2k1 Max SE)at the same pumps I'm overfilling at now. I assumed this was a design oversight but if it's only affecting a few of us maybe it's time to yell at the dealer!
Old Dec 27, 2001 | 05:27 PM
2001SE's Avatar
could this be a manufacture defect?
Maybe you should take it to the dealer, maybe something is wrong with the gas tank
Old Dec 27, 2001 | 08:52 PM
zman187's Avatar
If you have tried diffrent pumps, and there are multiple people having the same problem, then there is clearly something wrong with the car and you should inquire the dealer about it. Thats a problem which needs to be solved.
Old Dec 27, 2001 | 10:16 PM
ABS's Avatar
ABS
Don't Top It Off
This happened to me a couple of times right when I first got my 2K2. Then, I realized that I couldn't "top off" the tank, because it would cause it to overflow. Since I stopped "topping off" I haven't had any spills . . . good luck!
Old Dec 27, 2001 | 10:19 PM
pcante1's Avatar
SOMETIMES IF YOU DONT PUT THE NOZZLE ALL THE WAY IN,THAT WILL HAPPEN.
flu2000
22
Sep 2, 2015 07:29 AM
ffcbairn
Aug 27, 2015 11:55 AM
seesole
Aug 26, 2015 11:22 AM
Samedi
Aug 13, 2015 04:05 PM
