Failing Coil Packs?
Old Jun 28, 2011 | 09:59 AM
djkevinnn's Avatar
Failing Coil Packs?
I've been getting the wonderful Random Cylinder Misfire about once every three months since March, and Sunday it finally became a Cylinder 4 Misfire, so I figured it's time I get this fixed. I pulled my front 3 coil packs to test them since cylinder 4 is there and I wouldn't have to pull the IM. Did some research on the org with testing the coils using a multimeter, and did that to mine. Here are my results:
Most other people that I saw in threads got 4 resistances, I only got 2. Plus, #2 and #6 are identical, whereas #4 is a bit different. I wanted to get anyone else's insight on whether these coils are bad or not. I know there are other things that can be causing the misfire, spark plugs or injectors. I have plugs coming in tomorrow and I'm doing the full set considering I just passed 82k on my 03. Also going to replace the valve covers with those from an 04. Any help with this would be greatly appreciated.
Old Jun 28, 2011 | 10:03 AM
phatboislim's Avatar
find it kind of wierd for the front ones to go, especially since you only have 82k
Old Jun 28, 2011 | 10:09 AM
djkevinnn's Avatar
You think they're gone? I'm not sure, I'm just trying to compare to other's results on the org.
There's the info from this thread http://forums.maxima.org/5th-generat...ow-w-pics.html
Just not sure if the fact that I only have 2 readings mean that my coils are gone.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
howardis
Dec 11, 2019 06:10 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
