Well its My turn (Engine Problem)
Old Jun 28, 2011 | 10:09 AM
cjandura's Avatar
the 03 has been sitting now for 2 weeks due to me having welders eye(97 max lower support repair) and today was dreary out so i put on my perscription #10 goggles on and went and started up the car.The car started up fine as usual but after about 10 minutes idling it started to sputter and shake like it has a miss so i cut it off and restarted it.same exact thing idle for about 10 minutes then the sputter and shake starts i have no codes and i swapped out the maf before starting it the 3rd time.right now im kind of limited to how much time i can spend in the light so im hoping for some solid suggestions for when i can start eliminating the problem(s).
Old Jun 28, 2011 | 04:14 PM
spock's Avatar
First off, take care of your eyes. They're the only set you get.Then I think you need to take the car out for a drive instead of idling it for so long, (not really that good for it), and then see,(pardon the terminology), what happens.
Old Jun 28, 2011 | 04:49 PM
00Lightsout's Avatar
^^ agree! The ECU needs to re-learn/reset all the sensors after a MAF install. Have a buddy drive it around for a good 15-20 mins while you have your goggles on or are blindfolded...if you are blindfolded you will become more 'one' with the car and actually diagnose it better
Wow man, your eyes must have gotten scorched for them to still be limited Sorry for ya, bro!
Old Jun 28, 2011 | 05:12 PM
Eirik's Avatar
<-- The ECU didn't have to do a darn thing when I swapped MAFs.
Old Jun 29, 2011 | 12:37 AM
^^ So you thought usually when you replace your MAF it's b/c it throws a code. And you NEVER disconnect/R&R a MAF with the battery still connected... So you disconnect the battery to install the new MAF, then reconnect the battery after the complete install. The 10 mins that it took to reinstall the intake has caused the ECU to loose memory on certain sensors, As I understand it that is why the CEL and code are cleared along with several other sensor memory points. Upon restart the idle MAY act a tad funny for a second or three, then restart the memory/learning on those said sensors. If the code has not cleared via battery disconnection, you simply 'clear' the code by forcing the ECU to loose that memory with a scanner.
hens the term re-Learn
Old Jun 29, 2011 | 03:40 AM
Eirik's Avatar
<-- Didn't unplug the battery, either.
Old Jun 29, 2011 | 06:26 PM
spock's Avatar
That means that the ecu is still using the perameters of the old setup b4 the new maf. It needs some drive time or to be reset in order to learn the new part. (As I understand it).
Old Jun 29, 2011 | 06:46 PM
Child_uv_KoRn's Avatar
Bad *** Newb
/never unplugs the batt
Old Jun 30, 2011 | 07:36 AM
cjandura's Avatar
i didnt unplug the battery.it wasnt a new MAF it was just a replacement i had in the trunk.im going to see if i can start it up tonight sight permiting.Lightsout yes scorched is the word the doc said my left eye had blisters on it like i had laser eye surgery or sunburn on the lining its bad enuff that they caint see damage until it heals up.LESSON here kiddies NEVER EVER weld without #12 or better shields on at least for stick welding and weld atleast arms reach away.
Old Jul 1, 2011 | 03:03 AM
HOLY CRAP MAN!!
Old Jul 1, 2011 | 03:31 AM
bds1304's Avatar
ive heard that if u take a slice of a potato, and place it on your eyes that it will take the burn away
tsi6001
Oct 3, 2022 10:23 PM
alixc
Aug 11, 2020 01:48 PM
trasmadean
Feb 1, 2017 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
