Clutch Burned out need epinions
Old Jul 4, 2011 | 09:01 AM
TopSpeedNY's Avatar
My clutch burned out recently any recomandations for boost ones a such as turbo
want a long active clutch strong stage 3 or 3+ and flywheel thank you guys.
Mike
Old Jul 4, 2011 | 09:04 AM
aackshun's Avatar
(Spec) Billet Flywheel + 6 Puck Unpsprung.
GBGH.
Old Jul 4, 2011 | 03:23 PM
maxspeed96CT's Avatar
The original VQ...
I just installed my clutch masters stage 1 with fidanza flywheel. I love the way it grabs, and fell like the light flywheel helped low end power . But the chatter is bad.
If it doesnt get better with break in im considering even removing my polly motor mounts and going back to stock its so bad...
Old Jul 4, 2011 | 07:15 PM
TopSpeedNY's Avatar
GBGH.
whats the diference between unsprung and sprung clutch disc and which stage company is it. How long did you had since install.
Old Jul 4, 2011 | 07:19 PM
TopSpeedNY's Avatar
The clutch masters stage 1 how long you had it since install. I know for sure that each stage is different material i heard some good news with carbon material clutchs since they are flywheel and transmission friendly.
Old Jul 4, 2011 | 07:21 PM
TopSpeedNY's Avatar
anyone else who might have stage 3 or 3+ clutch and pressure plates.
want to know how long its been since install and if there are any chatter.
Thanks.
Old Jul 5, 2011 | 02:26 AM
The original VQ...
it only has about 2-300 miles on it since the install...
Old Jul 5, 2011 | 06:05 AM
aackshun's Avatar
I'm just trolling. I just have a Fidanza Alum Lightweight FW, and stock 350z clutch, stock 6mt pp, good enough for my current power level.
But seriously if you really plan on having a serious setup, I would look into what I just said lol.
Old Jul 5, 2011 | 02:24 PM
McSteve's Avatar
I have the Exedy Stage 1 and the Fidanza and have only 250 miles on it, but no chatter whatsoever.
Old Jul 5, 2011 | 03:32 PM
The original VQ...
I had a exedy stage 1 before and it was smooth, but felt like a stock clutch and didnt grab hard at all.
Only lasted 10k n/a I dont think it would of held up very long on a boosted max...
Old Jul 5, 2011 | 03:36 PM
QT1 5MT AE's Avatar
Gram Lights addict
what kind of torque numbers are you putting down? helps narrow down your options
Old Jul 6, 2011 | 09:34 AM
TopSpeedNY's Avatar
Thanks Guys for all your answers appreciate it I want to put down any where from 400whp or 450whp
Old Jul 6, 2011 | 09:43 AM
Shift_Max's Avatar
I had clutchmasters before and i only heard chatter from it.
Old Jul 6, 2011 | 12:02 PM
TopSpeedNY's Avatar
Which stage was it thanks.
Old Jul 6, 2011 | 11:46 PM
q.man06's Avatar
Pretty much any clutch that has "pucks" is going to have some chatter.
Street disks are probably not going to give you much if any chatter.
Unsprung = very very little friction zone on the clutch pedal
Sprung = Like stock friction zone
Just get a street disk with a heavy duty pressure plate and you'll love it. Just make sure you go by Torque goals rather than HP, because that's what clutches are rated by. -- if you're hoping to make 350wtq, then get a clutch that can hold more than 350wtq....
A stage 5 from ACT will probably hold a different torque rating than stage 5 from clutchmasters...
Stages don't mean anything really.
Old Jul 7, 2011 | 02:24 AM
The original VQ...
My Clutch masters stage 1 is not a puck style, its a normal disk. Still chatters like hell..
Ive driven my buddies max with a ACT stage 1 before and the chatter wasnt as bad..
But If you plan on making 400whp your going to have to take some chatter.
G/luck
Old Jul 7, 2011 | 09:50 AM
q.man06's Avatar
G/luck
hmm... I know my six puck clutch gave me tons of chatter, but my new clutch which is a street disk with a heavy duty pressure plate is like butter and holds more power.
It could be that it didn't break in properly, i've heard of chatter issues in that case. Same with things like motor mounts being too soft, i know when I put those poly bushing motor mount inserts in my chatter was significantly reduced on the 6 puck.
I know my stock one on my maxima chatters every once in a while but that's because it's on it's way out.
Every clutch can chatter, all i'm saying is that it is possible to get a setup that can hold decent power without chatter.
Old Jul 7, 2011 | 03:19 PM
The original VQ...
You have a clutch masters street disk aswell ?
I have polly mounts, im considering switching back to stock cause my chatter is so bad. Whole front end vibrates when you start from a dead stop.
The clutch only has about 500 miles on it right now.
Is it not broken it yet?
And it chattered bad from the minute I put it in and hasnt gotten any better.( s proper break in isnt the issue)
I have a 12lb fidanza im sure that is making it worse aswell.
Im sure stock fly would have alittle less chatter..
Old Jul 7, 2011 | 04:18 PM
QT1 5MT AE's Avatar
Gram Lights addict
stay away from act. get yourself a clutchmaster or clutchnet
Old Jul 7, 2011 | 04:55 PM
Child_uv_KoRn's Avatar
Bad *** Newb
damn it, 5.0 gens need a flashing light
HR Z stock clutch, problem solved
I doubt enough power will be made to need much more.
Old Jul 7, 2011 | 04:58 PM
QT1 5MT AE's Avatar
Gram Lights addict
for 400wtq huh?
Old Jul 7, 2011 | 05:05 PM
Bad *** Newb
Originally Posted by QT1 5MT AE
for 400wtq huh?
For regular driving, I'm sure. Unless you're gonna keep running it at the track. Power shifting and **** like that would destroy it in a hurry, but that won't do any good on a boosted maxima LOL. Spin till 5th gear if you did.
http://www.osgiken.net/ ?
Old Jul 7, 2011 | 11:39 PM
QT1 5MT AE's Avatar
Gram Lights addict
why would anyone aim for 450whp and do regular driving? HR Z's put down less than 250 wtq, so i doubt their clutch can handle anything remotely close to 350wtq.
Old Jul 8, 2011 | 12:13 AM
q.man06's Avatar
I don't, my experience is on my turbo civic which both the 6 puck and the street disk setup are from LSD motorsports. 500 miles should be broken in by now, but a lot of that depends on driving style/clutch technique.
That's odd to me you're getting so much clutch chatter on a street disk. I've driven several different cars from mine which have excessively heavy duty clutches, one in which held 640whp on a 94 prelude... none of them had pucked clutches and none of them have had any chatter to speak of; however, they all were running stock flywheels too.
Maybe a broken spring? flywheel surface not flat/flush with the disk? I dunno man, seems odd to me.
I know switching to poly bushings helped keep the chatter down substantially when i ran my 6 puck.
Old Jul 8, 2011 | 12:15 AM
q.man06's Avatar
x2 -- cheaper to do it right the first time.
Old Jul 8, 2011 | 02:24 AM
The original VQ...
You cant compare your clutch setup on a 2500lb civic to a heavy 4dr sedan.
Its apples and oranges
Im not the only one getting chatter, from what Ive read now the clutch masters like to chatter ...
Old Jul 9, 2011 | 01:35 AM
q.man06's Avatar
I guess I don't see why not... but ok.
Good to know about clutchmasters-- won't buy from them if I ever do work to the maxima.
user 11122324
42
Jul 18, 2022 03:35 PM
mclasser
22
Nov 12, 2020 01:58 PM
spencerwh1
Jun 30, 2016 05:44 AM
carlosvq30
Sep 26, 2015 09:44 AM
