AC compressor help
Old Jul 6, 2011 | 11:55 AM
NissanTun3r's Avatar
AC compressor help
Hey so my old ac compressor's clutch went bad after 170k miles, so I put in a NEW compressor this morning.
The install was easy, I finished up, took my car to a shop to get it evacuated, and then I went to put freon in my car from the r134a can's you get at autozone.
The problem is, for some reason my clutch won't engage. I jacked up the car, rechecked the clutch connector and it was in and secure, the lines were secure(with new o rings of course), I put half the bottle of freon in there, or about 7oz and the clutch still will not engage. I did oil the new compressor as well as according to my haynes manual.
Any ideas of WTF is going on with my car!?
Old Jul 6, 2011 | 11:57 AM
Mr. Brett's Avatar
You only added 7oz. of freon?
I'm pretty sure the Maxima takes a pound to a pound and a half...
If there's not enough freon, the clutch won't engage.
Old Jul 6, 2011 | 01:01 PM
njmaxseltd's Avatar
Why didn't you have the shop that evacuated it simply charge it by weight with the a/c machine - which is the only way to get the correct R134 charge?
Your clutch isn't energizing because you don't have enough pressure (charge) in yet.
Old Jul 6, 2011 | 02:08 PM
Well the shop said their machine to charge it was broken and since they were evacuating it for free I didn't complain.
I'll go home and add more tonight. Is it ok to keep charging it even thought the gauge is in the red? I charged it to 80 psi according to the gauge on the can but I got worried I'd overfill it so I stopped and hd only use about 7oz.
Old Jul 6, 2011 | 08:06 PM
Nelsito65's Avatar
If you don't have one, it would be wise to get a gauge. That would eliminate the dangers of overfilling the system.
Old Jul 6, 2011 | 09:28 PM
pmohr's Avatar
No more Maximas...
I wouldn't put much faith in the pressure gauge that comes with the can (assuming you got a can with a built in gauge, not a separate low side gauge. Those are better, but still not nearly as useful as a manifold gauge set).
If you only added 7 ounces, keep going. As said, charging by weight with an actual scale is best, though you can get it relatively close with known can sizes.
The system holds 1.3-1.5 lbs, you're at less than half a pound right now. Compressor turn-on is at 26 psi, you're not even at that yet.
I wouldn't go so far as to say eliminate, but would certainly lend more insight into relative charge level. Even reading static pressures requires some knowledge on how ambient temperature and humidity affect the readings.
05' MaximaMan
Oct 8, 2017 06:36 PM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
pears
Sep 18, 2015 05:25 AM
