power locks and sunroof
Old Jul 10, 2011 | 12:24 PM
Thomas2323's Avatar
Is there a fuse that controls the sunroof and power locks as one fuse? I had my car aligned and the lock won't lock with the alarm key and my sunroof only goes up and down but not backwards.
Old Jul 10, 2011 | 03:05 PM
DennisMik's Avatar
The fuse that powers the sunroof also powers the other windows, the seats and a few other things. Since the sunroof works partially, the fuse is good.
This sounds like one of those quirky things where you will have to re-program the keyfob remote and do the re-learn for the sunroof.
Old Jul 11, 2011 | 10:46 PM
lapdog12's Avatar
i sometimes have the problem with the sunroof not going back after i have removed the negative battery cable to do work on the car. the solution to get it working is very simple, at least in my case.
i'm a noob so my explanation will be won't be great but i hope you'll understand what i'm saying.
just hold the sunroof up and down toggle button (hold the side closest to the windshield) hold that one side down for about 10 seconds or so and that resets it. you should be able to get the sunroof to go back after that.
good luck.
Old Jul 12, 2011 | 08:51 PM
lapdog12's Avatar
Thomas2323,
curious if you were able to fix your problem.
Old Jul 14, 2011 | 11:31 AM
Thomas2323's Avatar
yeah I read somewhere else about how to reset the sunroof and it worked. Thanks for the help. I also found out that for whatever strange reason the lock on the driver door just went out. I paid about 40 and a guy fixed it for me.
Old Jul 14, 2011 | 01:08 PM
lapdog12's Avatar
cool, glad you got it fixed. i remember when the sunroof thing happened to me and i had no clue what to do, that's when i discovered the org. also found out how to reset my driver's side window that was going up and then coming down about 2 inches. this place is full of great info.
bigdogsteve
Jan 31, 2018 04:18 PM
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
