2002 maxima exhaust
Old Sep 3, 2011 | 04:08 PM
nick dolce's Avatar
2002 maxima exhaust
im looking into getting an exhaust for my max but i really cant figure out which one will be the best fir i want a deeper sound but not ricer kind lol the cattmann one is a little too expensive does anybody else have any ideas on other exhausts
Old Sep 3, 2011 | 04:17 PM
T_Behr904's Avatar
How many mods do you have already? Alot of people here on the Org tend to go with 3 inch exhaust for maximum performance, but it will be louder. Megan makes a nice 2.5 inch exhaust. BRM also makes affordable exhaust in either stainless or aluminized steel. BRM has options to choose from, such as 2.5 or 3 inch exhaust if you want more performance, and different resonator lengths, and single or dual tips. Also look on You Tube for various exhaust videos. It can give you a general idea as far as the tone and sound level, but IMO it's still not the same as hearing an exhaust in person.
Old Sep 3, 2011 | 05:48 PM
03VQMAX's Avatar
BRM is a suggestion like ^ said, that might be my future exhaust.
Old Sep 3, 2011 | 06:30 PM
Rods03Max619's Avatar
How much are you willing to spend, then that will tell you Cattman, BRM, or Megan Racing all sound good, none are ricer little fart cannons...
Old Sep 3, 2011 | 07:28 PM
kbcnd's Avatar
Not trying to steal the thread...but will a 3" exhaust bolt up to stock exaust or do you need some sort of adapter for it? Thanks.
Old Sep 3, 2011 | 07:32 PM
03VQMAX's Avatar
Its either a 3" exhaust or a stock exhaust, your not bolting them together.
Old Sep 3, 2011 | 07:38 PM
maxspeed96CT's Avatar
The original VQ...
If you a baller on a budger the brm or megan are good.
If you want to squeeze out every Hp possibe the 3" will help. But unless your boosted or have every other bolt on possible with a good tune you'll just be waisting your money.
I have a obx headers, megan muffler with ebay piping and a magnaflow resonator.
http://forums.maxima.org/5th-generat...n-muffler.html
Old Sep 3, 2011 | 08:02 PM
kbcnd's Avatar
Ok, sorry, just trying to understand all of this. So if I go 3"; everything from headers back needs to be 3". However, if I just get a 2.5" Megan axleback, I can simply replace the stock axleback with the Megan without any modifications correct?
Old Sep 3, 2011 | 08:14 PM
T_Behr904's Avatar
All the Megan's I've seen for sale have been cat-back, not axle-back.
Old Sep 3, 2011 | 08:15 PM
03VQMAX's Avatar
As long as the flanges match, you can put a 3", 2.5" or 2.25"
Old Sep 3, 2011 | 08:25 PM
T_Behr904's Avatar
Wouldn't you need some sort of step or reducer to smoothly transition the exhaust flow from one pipe size to another? If not, I'm sure that would cause alot of turbulence which would create backpressure.
Old Sep 3, 2011 | 08:50 PM
03VQMAX's Avatar
I was thinking that lol, I don't know much about exhaust other than it going from the front of the car to the back . But I'm pretty sure I've seen the 3" Cattman catback bolt up to a stock cat, I might be wrong.
Old Sep 3, 2011 | 08:54 PM
T_Behr904's Avatar
If I were to run a 3'' Cattman, I wouldn't bolt it up to the factory cat, that's for sure. I'd pony up a few bucks more and get a high flow cat or a test pipe to take full advantage of running an exhaust like that.
Old Sep 3, 2011 | 09:19 PM
amixamse's Avatar
Someone should post a pic of a factory VQ exhaust from manifolds to muffler, that would reduce the confusion.. I thought there were two precats off each manifold, wouldn't u need two test pipes? Alot of precat gutting goin on lately, y not just get a test pipe?
Old Sep 3, 2011 | 09:25 PM
T_Behr904's Avatar
The test pipe would replace the main cat. A fed spec Y-pipe (not cali) for my 2000 would replace both pre-cats. Or if you got headers, both pre-cats would be gone since the main cat would bolt up to the header collector. There are some pics floating around of before and after installs on a few threads.
Old Sep 3, 2011 | 09:44 PM
nelledge's Avatar
"I'm just sayin'..."
...Alot of precat gutting goin on lately, y not just get a test pipe?
Simple answer? It'll probably cost you less(time and money) to buy and install headers then it would be to custom fit test pipes where the precats are. You'll know what I mean once you see the precats. This thread is specifically for the 5.5
Old Sep 7, 2011 | 12:29 AM
vq_ryder's Avatar
Megan 2.5 FTW bro. not cheap, expensive or riced. if anythings megan, never buy the megan test pipe lol, unless u want to cut and reweld. also were u looking for dual tip like cattman/megan/brm/axleback hks or a single big ol woppin one like greddy/obx/egay?
Old Sep 7, 2011 | 01:58 AM
tcb_02_max's Avatar
I currently have a Megan Racing OE-RS catback, which I like a lot. Looks good, sounds great. If it is still too expensive for you, you could always pick up a used one.
On an unrelated note, I will be selling mine in the beginning of December after I install my Cattman 3".
Old Sep 7, 2011 | 04:21 AM
BobPezz's Avatar
I'm very happy with the "SRS Type-RE" catback. See this post http://forums.maxima.org/5th-generat...ml#post8249660
Old Sep 7, 2011 | 04:33 AM
The original VQ...
A high flow cat will give a n/a car the same power as a test pipe . I dynoed my cts-v after pulling off the high flow cats and the numbers where identical .
I know the smell doesn't bother others but mine would make my house smell a little since my garage is below. Plus idling at a light it smells sometimes aswell...
Nintensity
Aug 13, 2015 05:41 PM
fastcarny
Aug 12, 2015 03:50 PM
papo99
Aug 9, 2015 07:24 AM
yat70458
Aug 3, 2015 01:16 PM
