Consult 2?
Old Sep 11, 2011 | 03:50 PM
sc0tty8's Avatar
Consult 2?
http://cgi.ebay.com/ebaymotors/CAN-B...item23141ec1b2
Is this the tool in question for bumping up the timing? My assumption would be that I need to supply a computer and the software that comes with it is all I would need?
For $30 if that is the case, cool. For $30, I wouldn't be surprised this isn't the case
Old Sep 11, 2011 | 04:50 PM
buddywh1's Avatar
I wonder if it comes with the software, but no license? You'll have to buy a license on-line to enable it... just a thought.
$32... that's just way to good to be true.
Old Sep 11, 2011 | 04:53 PM
sc0tty8's Avatar
That's what I am thinking. I've never seen a unit so I wouldn't know. They have others that look like they have a hand-held lcd unit so I am not sure...
Old Sep 11, 2011 | 05:10 PM
Clashez's Avatar
It should work, i been looking at this for a while now ....
Old Sep 11, 2011 | 06:23 PM
mahanddeem's Avatar
Somebody please try it and give us a feedback
Old Sep 11, 2011 | 06:24 PM
Kevlo911's Avatar
Kevlo for President
i have it dunno if it works with 5th gens. i use it with ecutalk
Old Sep 11, 2011 | 07:11 PM
mahanddeem's Avatar
You use with ecutalk ? what is that and on what car do you use it ? does it work or what ?
Old Sep 11, 2011 | 07:31 PM
Looks like I just added another item to my watch list..
Old Sep 12, 2011 | 01:38 AM
knight_yyz's Avatar
Toolie
ut's only a consult one. So only works up to 99. Can't advance the timing on a 4th gen
Old Sep 12, 2011 | 03:28 AM
SteveB123's Avatar
Try ....what?
Read the listing....
It's a connector cable between an OBD2 port and a PC.
"- No software is supplied with this device
-It works on all Nissan cars that have the grey 14pin Consult connector (you'll usually find it near the fusebox) (This cars are usually build from year 1989 to 2000)"
Old Sep 12, 2011 | 05:23 PM
Kevlo911's Avatar
Kevlo for President
http://www.ecutalk.com/
Google
Correct
Originally Posted by SteveB123
Try ....what?
Correct
Old Sep 12, 2011 | 07:47 PM
knight_yyz's Avatar
Toolie
If I went on Ebay and said I had a consult 5xgt and it could program any car from Ford to a Zonda then it must be true.
Old Sep 13, 2011 | 07:02 AM
NmexMAX's Avatar
dot dot dot ...
I still say go with UpRev Cipher. 200$ with a lot of options. It uses the Consult II interface.
Old Sep 13, 2011 | 07:24 AM
MrEous's Avatar
^ Jeff™
Consult II is only a handheld device.
I have the Cipher cable and it's worked just fine for advancing timing. You can also do a TON of datalogging which I plan on utilizing very soon. I run Cipher through a little netbook so the whole setup is very minimal.
I'd trust products like the one listed above as much as almost anything else on eBay...which isn't saying much. You really do get what you pay for 99% of the time.
Old Sep 13, 2011 | 10:35 AM
knight_yyz's Avatar
Toolie
So the uprev cipher for 350z works on our cars, but not the osirus?
Old Sep 13, 2011 | 10:52 AM
NmexMAX's Avatar
dot dot dot ...
That's right.
Old Sep 13, 2011 | 11:23 AM
MrEous's Avatar
^ Jeff™
...and UpRev has -0- intention of updating Osiris to tune 2003 and less Maximas too.
Old Sep 13, 2011 | 12:06 PM
Dark_man_x's Avatar
Consult 2 will work for cars past the year 2000. you have to get a seperate cable end that has an OBD hookup. But for 30 bucks, good luck is all i have to say. You wont get any data cards that go with it and from Nissan I think its about 5 g's
Well nevermind about the data card thing. I thought it was the actual handheld yellow Consult 2. but I guess not..
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
torontoboy
Nov 15, 2002 07:23 PM
rcrdps
Mar 19, 2002 01:36 PM
yongjun
Feb 27, 2002 12:27 PM
