Torque spec for rear caliper banjo bolt
Old Sep 25, 2011 | 12:17 PM
gdal's Avatar
I'm currently in the process of replacing both of my rear calipers. The repair book that I'm using states that the rear banjo bolt should be torqued to 144 ft-lbs. The washer and fitting started distorting really bad after a using my torque wrench. I'm pretty sure my banjo bolt and fitting are shot.
Does anyone know here if that's the right torque spec?
Thanks,
G
Old Sep 25, 2011 | 12:22 PM
nelledge's Avatar
"I'm just sayin'..."
What 'repair book' are you using?!? It should be 12-14 ft*lb. Wow, that sucks. Your book must say 'in*lb'.
Use this from now on.
Old Sep 25, 2011 | 06:06 PM
CMax03's Avatar
144 in lbs is 12 ft lbs i"m sure it's in in lbs as well
Old Sep 25, 2011 | 06:45 PM
gdal's Avatar
I realized the unit issue after messing up the assembly. I replace the brake line, but I couldn't find the brake hose bolt anywhere.
Old Sep 26, 2011 | 06:54 AM
sontakke's Avatar
See, if only you had NOT used the torque wrench :-( Without it, you would have used the common sense and would have tightened it as much as needed.
But you are not first person who has done this kind of stuff.
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
Team STILLEN
Aug 10, 2015 04:29 PM
RealityCheck
Aug 5, 2015 06:18 AM
