Replacing Upper Oil Pan Gasket questions...
Old Oct 28, 2011 | 12:48 PM
lapdog12's Avatar
I have a leak from my upper oil pan gasket and need to get it fixed. I don't have the tools or the knowledge to do this project so I'm taking it to my mechanic. I know it's expensive because of all the time involved.
My question is...
What else should i get done to my car while this is being done? Since I'll have the top of the engine off is there any other maintenance that i should have done?
I'm a noob to all of this. Here are the specs on my car:
2003 SE automatic. approx 112,000 miles
i've replaced the primary O2 sensors, did the MAF swap, keep up with all my scheduled maintenance.
i did notice on my last smog check that my hydrocarbons were high this might mean my cats are going.
Any info would be great. I might as well take care of certain things while i have that part open.
also, would this make the rear main seal reachable, should i have that done too?
thanks for your help
Old Oct 28, 2011 | 01:45 PM
nelledge's Avatar
"I'm just sayin'..."
Quick response: You won't have the "top of your engine off" for the oil pan reseal. Make sure they replace front and rear lip seals, oil cooler seals, internal tube oring(x2), lower oil pan reseal or gasket, ypipe gaskets. I think that's it. Don't let them talk you into changing the RMS until they physically show you a leak from it. Many mechanics automatically see a leak at the rear of the engine and jump to that conclusion. The majority of the time it is the rear lip seal.
Old Oct 28, 2011 | 01:53 PM
OnOiShNo0dl3Z's Avatar
Editing response, looks like nelledge is saying that you won't have the top of your engine off.
Old Oct 28, 2011 | 02:27 PM
lapdog12's Avatar
ok... thanks for that info. they (my mechanic) haven't mentioned anything about the rear main seal, but I myself have noticed it being gunked up and moist looking dirt around where i think the rear main seal is, but i've never noticed any actually leaking from there.
thanks for letting me know about what is actually done. i just didn't know if they are going to access that part of the engine if there is anything else i should have done (maintenance wise) while they are at that part of the engine.
thanks again for your input!
Old Oct 28, 2011 | 02:57 PM
nelledge's Avatar
Originally Posted by lapdog12
...thanks again for your input!
You're welcome.
ok... thanks for that info. they (my mechanic) haven't mentioned anything about the rear main seal, but I myself have noticed it being gunked up and moist looking dirt around where i think the rear main seal is, but i've never noticed any actually leaking from there...
The lip seal is underneath the RMS. Most people can't determine which is leaking until the pan is off. I would almost bet money that the RMS is fine. BTW... the RMS change will add quite a bit of labor cost.
...i just didn't know if they are going to access that part of the engine if there is anything else i should have done (maintenance wise) while they are at that part of the engine.
You could change the belts while they're off if you haven't done those.
Old Oct 28, 2011 | 03:23 PM
lapdog12's Avatar
i just looked over my maintenance records and i see that i changed my belts on july 11, 09 at 91,900 miles and i'm at around 113,000 so i think i'm ok there but i will have them inspect them, they look fine to me.
Again thanks for all the info. I've found the part number for everything but the y-pipe gasket, but i'm sure i'll find that soon. i just want to know the prices for these parts so i don't get over charged. they all seem relatively cheap.
thanks again for the quick response and answering my questions. if i'm going to spend the money to get it done i want it done right and take care of everything i could take care of while i have that part of the engine exposed.
PH98I30
Jan 9, 2025 08:08 AM
Matt93SE
Apr 8, 2018 09:23 AM
iflexsteel
Sep 15, 2015 03:37 AM
homeyclaus
Sep 3, 2015 06:15 PM
maxima297
Aug 3, 2015 12:50 PM
