rubbing/squeaky noise when turning
Old Oct 28, 2011 | 03:43 PM
2damax's Avatar
Car can be idle or moving and sound is still there. Sound seems to be from the front passenger but might be driver. I wont know until i have time to listen. I recently changed the suspension and brakes. I just did a quick check and PS fluid seems to be correct and a quick inspection of the wheel well shows no signs of damage. Anyone have insight on what might make the sound. Its almost like a lower pitch belt squeal sound.
Thanks in advance.
Old Oct 28, 2011 | 04:08 PM
Ghost_54's Avatar
I assume that the caliper was moving nicely before you re-installed the new brakes, have you re-checked the new brake pads? perhaps one or both are not seated properly and one side may be dragging on the rotor.
Old Oct 28, 2011 | 06:41 PM
2damax's Avatar
I replaced a caliper when i did the brakes. I will check the pads. I ordered hawk pads and the box said fronts but they didnt match quite right. That will be my first check next day off. Thanks
Old Oct 28, 2011 | 06:49 PM
2damax's Avatar
I just got out if work. Start my car and leave the door open to listen. Right now it is only when the wheel is fully or ALMOST full turned and it sounds more like someone spraying air or a hiss even...
Old Oct 28, 2011 | 06:52 PM
2damax's Avatar
Edit: squeaky is still there. Only can hear it with doors shut inside cabin....sorry bout 3 quick posts
Old Nov 15, 2011 | 05:14 AM
Bronzie2K's Avatar
If it's coming from the passenger side and sqweaks at idle I would suggest checking the belts. I had a similar problem after installing new brakes and it turns out the calipers where the problem.
Old Nov 15, 2011 | 07:42 AM
Sebs's Avatar
I've got that same problem but never thought much of it. It only makes the sound when the wheel is turned all the way on one side but not all the time.
Old Nov 15, 2011 | 12:03 PM
LongoTE's Avatar
Mine also makes a kind of hiss/moan/whine when fully locked but its not really noticeable. I always assumed it was just part of the hydraulic system.
pears
Sep 18, 2015 05:25 AM
lrb6805
Sep 17, 2015 04:49 PM
LtLeary
Sep 14, 2015 12:33 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
