CRIKEY! Oil in the UIM - help?
Old Dec 6, 2011 | 01:15 PM
nissandrvr98's Avatar
So i installed my NWP BOP yesterday and found the VIAS covered in oil and a bit of oil in the bottom of the UIM. cleaned it all out but i imagine it'll continue until the cause is remedied.
i searched a bit and found some info regarding PCV etc (i was under the impression my 02 does NOT have a PCV). so, that said..anyone have any thoughts on why there is oil there and how i might go about fixing it?
Thank you!
Old Dec 6, 2011 | 01:38 PM
Chris Gregg's Avatar
Get Off My Lawn
You do have a PCV. An oil catch can will help. You can do an advanced search for oil catch cans in the 5th gen section.
crazy97's Avatar
Thank you!
Pretty common on the 5.5 gen.. 0/5/10W-40 will cut your oil consumption when you find out you are having that issue also..
Old Dec 6, 2011 | 01:39 PM
huh...shows how much i pay attention. the pcv routing diagram under the hood makes more sense now too.....thank you. >off to search.
@crazy97
ok, noted. i currently run M1 5w30 all year round. little heavier wont hurt at all (esp at 152k)
Old Dec 6, 2011 | 01:44 PM
crazy97's Avatar
@crazy97
Im using 0W-40 Mobile 1 and its cut my oil loss by 70%. No noticable issues, car still runs great. 138K
Old Dec 6, 2011 | 01:48 PM
crazy97's Avatar
I had the Home Depot catch can. It was a PITA! In the winter time it would fill up with mostly fuel vapors and some oil, but I had to empty it every few days. Plus I was getting a nice oil smell in the cabin. When I took off the can the smell went bye bye!
Old Dec 6, 2011 | 01:49 PM
thats on a 3.5?
Old Dec 6, 2011 | 01:54 PM
crazy97's Avatar
thats on a 3.5?
Yes
Old Dec 6, 2011 | 01:59 PM
right on...just curious. with a change due here in the next few weeks i'll be heavily considering a change over.
Old Dec 6, 2011 | 03:12 PM
altezzablazes's Avatar
Your manifold is sucking up oil mist through the pcv like a straw. try a official oil catch can. believe me. Home depot catch can is not reliable
Old Dec 6, 2011 | 07:40 PM
ranmas2004's Avatar
Man put breather filters on the front and back valve covers and plug the intake mani on the back and you CAI in the front and call it a day. That is what I did. Oil in the Mani affects power.
Old Dec 7, 2011 | 05:01 AM
after reading a bit on the home depot band-aid, i wasnt going that route. i'd rather drop in a proper catch can.
i'll continue reading on the topic for now, it'll probably be spring until i can get around to it now with the weather turning cold.
Old Dec 8, 2011 | 06:32 AM
Puppetmaster's Avatar
I had the same issue, but my car was a legitimate oil burner - losing a quart per 1000+ miles. I had oil in a couple of the spark plug chambers too. Replacing the rear valve cover (which has a pre-installed PCV, so don't buy another one) with a 6th Gen rear valve cover (it's cheaper, but fits the same and works better) helps a little.
Old Dec 8, 2011 | 07:11 AM
on my list for next spring is plugs (who knows how old they are-could be original), so i'll probably have a replacement 6th gen cover on hand and may look at doing a catch can then.
my oil consumption isnt bad-probably 1-1.5 qts/oil change (3500 miles)
Old Dec 9, 2011 | 12:38 AM
02 SE's Avatar
Oil catch can is a must on our cars. Got mine at Sears for $19
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
