'00 Max, evap code.. Experiences on fixes.
Old Jan 9, 2012 | 01:55 PM
CraigSE's Avatar
Dad's '00 is still running mint and until this recent problem, has never really had a CEL appear almost ever, except for when the MAF failed several years ago.
It is an evap code, the exact number escapes me but I believe it is the gross leak code.
I have replaced the evap canister and purge solenoid with another used one that was in good shape, with lower miles.
I also replaced the gas cap with an OEM gas cap from the dealer.
Still the code comes back a few days later.
What are the other things to check? Replacing the canister fixed this code completely on my '02 when I had it.
Old Jan 9, 2012 | 03:59 PM
Chris Gregg's Avatar
Get Off My Lawn
I would have put my money on the gas cap. Sure that stupid strap isn't in the way of the cap sealing? Rechecked lines where replaced the canister? Perhaps one of the rubber hoses/lines has a crack/leak in it?
Old Jan 10, 2012 | 09:00 PM
CraigSE's Avatar
Well that to me is the only other option too (cracked or broken lines) but I did not see anything when I was under there replacing the canister. I don't know if there is a way to test these lines somehow. Perhaps blowing some air in them, but I don't know if that is bad for anything or what. This whole evap system is like a black box I'd rather not know about
Will double check the gas cap... Thanks for the reply.
Old Jan 11, 2012 | 07:48 AM
Amave's Avatar
smoke test is your best bet to locate any evap leaks. sometimes a pinhole will cause the CEL to come on
Old Jan 11, 2012 | 07:02 PM
mau108's Avatar
My 01 had a EVAP gross leak code. Picked up a 10 dollar gas cap from the local auto parts store, reset the code and it hasn't been back in a month!
HOKUSMAX
Nov 13, 2017 04:34 AM
pears
Sep 18, 2015 05:25 AM
220k+ A32
Sep 11, 2015 02:18 AM
dcam0326
Sep 7, 2015 07:26 AM
Hailstatejig
Sep 2, 2015 06:52 AM
