Code showing Bank 1 Sensor 2?
Old Jan 23, 2012 | 03:45 PM
killer00's Avatar
Whats the Nissan part number for the Bank 1 Sensor 2?
should I use a Simulator?
Best place to get the simulator?
Would the simulator restore my mpg's?
Old Jan 23, 2012 | 03:49 PM
BigLou55's Avatar
if you have a stock exhaust setup you should just replace the o2 sensor with one made by Bosch the p/n escapes me...check out the stickies it could be in there. if you have headers and such then an O2 sim would be the way to go
Old Jan 23, 2012 | 03:56 PM
killer00's Avatar
I looked for it, can't find the p/n for the Bosch or nissan. I have a 2002, stock exhaust.
Old Jan 23, 2012 | 04:00 PM
cjandura's Avatar
15224 front downstream
15225 rear downstream
13968 upstream
Old Jan 25, 2012 | 01:05 PM
allornothing's Avatar
Just replaced the same one in december. Went to the dealer to get part, wow expensive $195.83, I'm pretty sure the part # 226a0-4L713. Post what the bosch part cost, I think there's 3 more to go, when one goes the others aren't far behind from what I hear.
Old Jan 25, 2012 | 01:40 PM
NmexMAX's Avatar
dot dot dot ...
http://www.courtesyparts.com/22690n-...ml?cPath=1956&
Your Price: $151.58
[22690N] O2 SENSOR, REAR
Fits this vehicle: Maxima (A33B) Bank 1 sensor 2, plugs into pre-cat
2002-2003 3.5L
Not your application? Choose another.
Genuine Nissan Parts
Quick Part Details
Manufacturer: Genuine Nissan Parts
Illustration: Maxima Parts (A33B) 2000-2003
Product SKU: 226A0-A33B004
Keep in mind, Courtesy doesn't use the same PN reference as Nissan. But, it's only 150+ vs 195.
Old Jan 25, 2012 | 02:09 PM
02whitemaximase's Avatar
I just sold that same OEM new sensor for 70 shipped. Deals are out there, just search a little. Even ebay.
Old Jan 26, 2012 | 01:38 PM
killer00's Avatar
The codes that I have now are P0420 and P0430.
So I guess I'll try to buy the catalytic converter
Old Jan 26, 2012 | 04:28 PM
BigLou55's Avatar
Have you ever tried resetting the code and see if it comes back? Just a quick and easy thing to try before you spend about 500-600 bucks on 2 cats
Old Jan 26, 2012 | 04:47 PM
killer00's Avatar
I replaced the sensor and I cleared the codes the P1147 and some other codes but light came on showing P420&P430, the P420 didn't show before I replaced the sensor and only showed the P430.
Old Jan 26, 2012 | 04:59 PM
BigLou55's Avatar
Clear it once more to be sure. I had to replace an O2 sensor and after doing so I got the p0430 code cleared it 2 times and kept coming back so i replace that cat cleared the code and then another code came for another O2 sensor. cleared it and it came back so replaced it reset codes and then the p420 came and I cleared that and it hasn't came back 5k later (knock on wood).
I understand everyones situation is different but it could work for you plus its free vs cost of a cat.
Old Jan 27, 2012 | 06:51 AM
killer00's Avatar
and I forgot to mention, I can hear rattling.
Old Jan 27, 2012 | 08:14 AM
ranmas2004's Avatar
If you going to buy cats for $600 and O2 sensors and all it would just be best to get headers for all the money you going to spend.
Old Jan 27, 2012 | 08:24 AM
ShocknAwe's Avatar
Yea I would try to reset the codes. Ive got those codes plenty of time and they have never been caused by a bad 02. New cat too? just because of the rattling or because you think its bad? You can always go pay a quick $20 for emissions and know for sure whether your cat is working or not. Not one of those cheap parts you buy new to eliminate a possible cause
Old Jan 27, 2012 | 09:59 AM
Professor's Avatar
funny thing is, i have this same code, rear sensor at the rear cat, since i put my new exhaust in, i havent welded a bung in for the sensor yet,so it is just zip tied under the car, and since ive done this i have not got a ses light yet haha
Old Jan 27, 2012 | 03:44 PM
killer00's Avatar
After clearing the codes, The codes reappeared P0420 and P0430, should I buy aftermarket headers? aftermarket exhaust?
Old Jan 27, 2012 | 03:52 PM
BigLou55's Avatar
well aftermarket headers would be a component of an aftermarket exhaust system. I think what you mean is should you buy aftermarket precats and be done with this issue OR delete the precats from your exhaust system and get some headers? If you had plans to install a nice exhaust system(headers, y-pipe , ect.) now is the perfect time to do so if its in your budget. If you have no plans of doing this just get some aftermarket precats and your done.
mvm062
Nov 30, 2020 09:00 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
220k+ A32
Sep 11, 2015 02:18 AM
