2k2 6 spd throttle hang
Old Jan 2, 2002 | 08:50 AM
Eric's Avatar
Hey all,
With 2k2 6 spd almost broken in, I've taken a few 3/4 throttle runs to 4000 rpm, and I've noticed there is a significant amount of throttle hang with the car.
At first, I thought I was screwing up my shifts so I started to make sure I had my foot completely off the gas before touching the clutch, and the same thing was happening.
Basically, I take my foot off the gas, hit the clutch, and the engine stays at the same RPMs. It even seems to blip up a few hundred rpm sometimes.
Is this just me or is anyone else experiencing this?
Old Jan 2, 2002 | 09:08 AM
ArcticMax's Avatar
It's supposed to be like that
The car does that to reduce emissions. Especially with the 2k2 drive by wire, engineers didn't give us total control.
Old Jan 2, 2002 | 09:12 AM
gtr_rider's Avatar
192.168.1.1
Re: It's supposed to be like that
Booooooooooooo on there part
Old Jan 2, 2002 | 09:23 AM
FastCougar's Avatar
Re: 2k2 6 spd throttle hang
Originally posted by Eric
Hey all,
Throttle hand is very common in modern cars as it is a way to reduce emissions. When the throttle snaps shut, a lot of unburn NOx's are produced. Car makers found out that by having the engine slowly come down in RPMs, these emissions are reduced significantly. This is accomplished by leaving the IACV (Idle Air Control Valve) open between shifts.
So, if this car is anything like the cougar, it is normal for the throttle hang. One way to combat this is to place a restriction in the IACV Bypass tube. To read more about this, click on the link below in my signature and do a search for "throttle hang" in the archived messages in every category. I also have a how-to on my website that details this simple solution that is easily reversable.
http://www.fastcougar.com/how_to/how...ttle_hang.html
There are some reasons why you may not want to do this. First, if given no way of breathing, the engine will be tempted to suck "air" past the PCV Valve and rings. This will cause the engine to stumble and die. However, I don't buy into this theory because the intake air is simply being restricted, not completely cut off.
Old Jan 2, 2002 | 12:19 PM
Creature's Avatar
Uhhh ... the 2K2 Max's throttle is not drive-by-wire, is it? The 2K2 Altima is but in everything I've read, both online and in Nissan publications, I've never seen it stated that the 2K2 is drive-by-wire.
It certainly doesn't feel like it is, anyway. The 2K2 Altima has a much more responsive and accurate throttle than the 2K2 Maxima does.
Old Jan 2, 2002 | 12:52 PM
Stereodude's Avatar
Try looking here http://www.edmunds.com/reviews/roadt...8/article.html
In addition to the stronger engine, other mechanical refinements include a "drive by wire" throttle control (that uses electronic control instead of the traditional throttle cable setup), a beefed-up automatic transmission (standard on GXE and GLE) and larger front disc brakes. The standard antilock brakes also feature brake force distribution (which gives the most braking power to the wheels with the best grip) and brake assist (which supplies full braking power when the brake pedal is applied suddenly, such as in a panic stop situation).
Old Jan 2, 2002 | 01:16 PM
Afty's Avatar
FWIW, my Altima 3.5SE 5-speed does the same thing. I don't like it either, but I guess that's the way it is.
Old Jan 4, 2002 | 09:38 AM
Creature's Avatar
My 2K2 throttle feels exactly the same as my 2K GXE did, including the throttle hang you guys are talking about. That's another reason I didn't believe the 2K2 went to a drive-by-wire. I thought this "throttle hang" was the notorious slipping auto tranny issue.
Old Jan 4, 2002 | 11:44 AM
Dave B's Avatar
Not DAVEB the parts guy
Ummm...look under the hood of your 2002 and tell me if you see any cables coming out of the throttle body
Dave
Old Jan 4, 2002 | 12:01 PM
Stereodude's Avatar
Dave
Shhh Dave... Don't let out the secret.
Stereodude
Old Jan 4, 2002 | 12:16 PM
max2001se's Avatar
Hey all,
Yeah as fastcougar said this is probably done to reduce emissions. Us 00/01 5spd guys get the same thing. RPMs wait a couple of seconds before dropping when I depress the clutch and during spirited driving and quick shifts the rpms rise 200-300 rpms. So it is probably not unusal.
Old Jan 4, 2002 | 01:13 PM
maxed's Avatar
Your shifting too slow if you notice
It bugged me too when I first got the car, but I've grown used to it and it doesn't effect my shifting any. The car is finally starting to break in become a pleasure to drive. The shifter has smoothed out and the clutch is developing some "feel". The ECU isn't being so conservative either. I swear that it wouldn't let me run WOT for the first week and kept the mix overly rich.
Old Jan 4, 2002 | 01:22 PM
nismo2020's Avatar
Needs non-Maxima Friends
2k2 v-6 alty same way
i drove one and everytime i would shift the engines revs would stay up. i found it to be real strange. espically after getting out of my car which the revs drop almost immediatly. i dont like it at all.
Old Jan 4, 2002 | 01:30 PM
FastCougar's Avatar
Re: 2k2 v-6 alty same way
Try my throttle hang fix ... the how to can be applied to almost any car that uses an IACV bypass tube and exhibits this behavior. If you don't like the result, take it out ... only takes 15 minutes!
Old Jan 5, 2002 | 12:53 AM
kit99bar's Avatar
I'm no car expert, could someone explain
what the disadvantages of not having the rpms drop down really quickly are? (other than using engine braking)
Old Jan 5, 2002 | 09:07 AM
swallac2
As they said a few posts above, it has to do with emissions. It keeps the tree huggers happy, but it ticks the rest of us off. It's hard to make quick shifts smooth with the throttle like this.
TallTom
57
Oct 14, 2025 05:16 PM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
ef9
Oct 4, 2015 08:43 AM
220k+ A32
Sep 23, 2015 03:38 PM
220k+ A32
Sep 11, 2015 02:18 AM
