Wont Start
Old Feb 26, 2012 | 07:15 PM
originalhandy's Avatar
Wont Start
So tonight the car decided it didn't want to start. I checked all the fuses and they are good, it doesnt even try to turn over. I lifted the hood and there is no clicking noise. What am I looking at, starter motor ?
Old Feb 26, 2012 | 07:19 PM
T_Behr904's Avatar
Check your battery and make sure it's still good.
Old Feb 26, 2012 | 09:30 PM
Battery seems to be OK, all the electronics come on no problem and they dont turn off when I try to start the car. I did try jump it, surely it would have started that one time for the jump ?
Old Feb 26, 2012 | 09:45 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Bang on the starter solenoid and try again.
Old Feb 26, 2012 | 10:21 PM
T_Behr904's Avatar
It's possible the starter could have gone out. when my starter quit, it didn't make any clicking noises. If you are sure it's not the battery, then remove the starter and have it tested.
Old Feb 27, 2012 | 10:47 AM
I banged on it with no joy.
Im gonna try track down a testlight and test it tonight.
Old Feb 27, 2012 | 03:28 PM
DennisMik's Avatar
When you get the test light, check the skinny wire that goes to the starter. When you turn the key to start the car, this wire should have 12 volts. If it does, the starter solenoid is bad.
If there is no 12 volts on the wire, other possibilities are a bad ignition switch or the 40 amp fuse labeled "FL40A IGN SW" that is under the hood.
If you have an auto trans, it could be 15 amp fuse # 20 (dash board fuses) or the Park/Neutral switch on the shift lever. Put the lever in neutral and see if it starts.
If you have a manual trans, it could be 10 anp fuse #21 (dash board fuses) or the clutch interlock switch on the clutch pedal.
Old Feb 27, 2012 | 03:30 PM
Bad *** Newb
That's what I call answers lol
Old Feb 27, 2012 | 03:50 PM
T_Behr904's Avatar
I tried that too and it didn't work. I replaced the starter on my car.
Old Feb 28, 2012 | 03:29 PM
Thanks Dennis, ill try the other things tonight. If not ill order a starter.
I appreciate the advice
Old Feb 28, 2012 | 06:43 PM
cabernet's Avatar
I had the same symptoms. It was the starter. If it's the original starter it's time to replace it. Do it yourself for under $100. Lots of threads in the last month on how to replace it.
Old Feb 28, 2012 | 09:42 PM
Yeh it looks simple enough so I will do it Monday when it arrives.
Old Mar 5, 2012 | 07:40 AM
Are there any good guides to removing the air intake to get to the starter and anything else I need to do for removal ? Some of the guides I have read havent been the clearest.
Old Mar 5, 2012 | 02:52 PM
DennisMik's Avatar
I am not aware of any guide for this but it's not that complex. You should be able to figure it out as you work on it.
Old Mar 5, 2012 | 03:11 PM
Ill try!
Wish me luck, im gonna try do it tonight. If you hear on the news of an Irish guy in New Mexico going postal tonight you will know its me
Old Mar 5, 2012 | 03:35 PM
TunerMaxima3000's Avatar
Dayum Dennis well done sir, you're so helpful. I missed this thread completely.
And it's possible that it's a bad ground even if you have 12V at the trigger.
It's also possible that there is a bad battery cable to the Starter solonoid or fuse blown in this circuit.
Just a couple other things to check/consider before you condemn a starter. But to be fair, 95% of the time if you ahve trigger power and it doesn't do anything, it's the starter that's the problem.
Bang on THE STARTER MOTOR, NOT the solonoid The solonoid will shatter if you bang on it
Old Mar 5, 2012 | 08:30 PM
I got everything apart and put the starter in and it all works great!
I really appreciated everybody's advice. It was my first actual job I have done on a car and I got it knocked out fairly quickly. Ill be sticking around to get more info from yous,
Thanks again
Old Mar 6, 2012 | 04:23 AM
Congrats dude, feels good eh!
Old Mar 6, 2012 | 11:18 AM
DennisMik's Avatar
Well, thank you. I get a lot of info from others such as your self and so I try to give back to the forum.
After reading so many posts, I have this theory in regards to bad grounds. It seems that those of you that live in the corrosion creating snow belt seem to have a lot of problems with grounding, while those of us in the sun belt are much less likely to have grounding problems.
Just throwing it out.
Old Mar 6, 2012 | 11:27 AM
^That is almost a certainty
Old Mar 9, 2012 | 12:49 PM
01maxium's Avatar
I have the same issue, but when I turn the key to the acc position the radio or clock does not turn on. I have power to interior and exterior lights, also checked all fuses under dash and they are all good. The car will not crank and I am starting to think it is the starter after reading this thread but I don't think that would affect the radio? Also I did a light test to the ignition wire and the fat green wire is +12V but the test light did not light up. Any ideas, could it be the starter?
Old Mar 9, 2012 | 01:59 PM
Did you check all the fuses under the hood also?
Soudns like it could be a bad ignition switch if your fuses are good, and you arent getting power to the trigger wire.
But wait, how do you have 12V+, but the test light isn't lighting up? I don't understand this, unless you tested it with a multimeter AND a test light?
Old Mar 9, 2012 | 02:12 PM
01maxium's Avatar
I meant to say the green wire is constant for those who did not know that, but I'm sure most people do. I would assume it is a bad ignition switch cause all fuses are good. Does anyone know how to fix that or how much it would cost to fix?
Old Mar 9, 2012 | 02:15 PM
You didn't answer if you checked the fuses under the hood as well as in the cab?
If you don't have power to your ignition switch then it's obviously not the ignition switch that's the problem....
Old Mar 9, 2012 | 02:19 PM
01maxium's Avatar
I did check the fuse in the cab and under the hood, all looked good to me but I will double check on that again and look closely, I just glanced at it because I was running late for work and my friend was giving a lift. I will keep up updated.
Old Mar 9, 2012 | 03:16 PM
Visual check is not sufficient.
I've been through this with 2 guys over on driver and one guy here this week. 2 of the 3 had blown fuses and they were "SURE" that all the fuses were good. Ill post how to check them for you in a bit.
Old Mar 9, 2012 | 03:35 PM
All you really need to quickly check fuses, without even pulling them out, under $6 at any local parts store:
12 VDC Incandecent test light.Hook the clamp to a good ground, and probe one side of the fuse with the key in the "ON" position. You should have power, now check the opposite side, you should have power there too. If you have power on ONLY ONE SIDE of any fuse, that fuse is blown.
With the above tool though you can easily check all fuses in under 5 minutes.
Old Mar 9, 2012 | 04:41 PM
01maxium's Avatar
Nice, thanks for that info, I would have never knew how to do that. I will test it out when I get of work in 30 minutes and let you know it that was the problem.
Old Mar 9, 2012 | 06:16 PM
01maxium's Avatar
Thanks for the help Turner, it ended up being the fuse. Just replaced and my car is drive able again
Old Mar 9, 2012 | 06:42 PM
That's 3/4 now
Gladtohear it mang.\\
Now you need to find out why that fuse was blown. To do this you need to know what circuit it is, then find out what's ont hat circuit and inspect those components. Otherwise you'll just blow the fuse again later on down the road probably.
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
