Gap in hid foglight beam
I noticed that my passenger side beam has a gap right in the middle of it. Is this an aiming issue? If so which direction do I turn the screw or whatever its called to aim up clockwise or counterclockwise? I think it needs to be aimed up but just not sure. I have a pic but photobucket is wierd on my phone I cant figure out how to upload photos.
Check you bulb to see if it's seated properly and peel your splash sheild back.....I modified my Oem Fogs so I could insert my 8mm deep 1/4" drive socket thru the adjustment hole....I'd suggest you turn the adjust screw and watch if the beam goes up or down!!!
First thing that should've been asked, are they oem or aftermarket lamps? I did the same thing CMax03 did, made a little hole to adjust height, I also had to bend my shield foward because of oem philips bulb being way too long..
Nah the other fogs beam is perfect nice n wide(thats what she said lol).What size bulb go in the shifter for an 03 I had shinjido make me a bulb but it was to big.
Heat0212
Oct 24, 2020 12:36 AM
ricky7780
Nov 3, 2015 03:22 PM
