Crank no start help!!!
Old Mar 21, 2012 | 03:33 PM
cmd26's Avatar
I turn the key I hear cranking then nothing. It doesnt do anything video to be uploaded tomorrow.
Old Mar 21, 2012 | 03:43 PM
foodmanry's Avatar
Da Roller Coaster!
So the starter is doing it's job?
How are the lights? Does it look like the battery is low? Maybe alternator?
It could be something with your security where immobilizer is still active.
It could also be related to your crankshaft position sensors or camshaft position sensor(s).
Old Mar 21, 2012 | 05:00 PM
cmd26's Avatar
Also discovered front and rear valve covers are leaking. This sucks.
Old Mar 21, 2012 | 05:23 PM
ShocknAwe's Avatar
valve cover seals are no big deal, happens on most of these engines and its a job you can do yourself. The cranking but no start could be a few things so lets start small. Any codes? How are your spark plugs and cam and crankshaft position sensors?
Old Mar 23, 2012 | 07:53 PM
cmd26's Avatar
Havent been able to check anything to busy at work so tomorrow vid and other analysist.
Old Mar 23, 2012 | 09:47 PM
TunerMaxima3000's Avatar
Sounds like low battery/slow cranking.
A little more description will help if you can't get the vid up anytime soon
Old Mar 23, 2012 | 10:49 PM
cmd26's Avatar
Battery is fine all lights work all electrical is fine. I think I overfilled it with oil
Old Mar 26, 2012 | 04:50 PM
cmd26's Avatar
Well no progress so im going to take it to a shop, my car is leaking oil like crazy.
Old Mar 30, 2012 | 11:08 AM
cmd26's Avatar
UPDATE:
The oil cooler o ring needs to be replaced and after getting it towed to the shop my car started right up which I dont understand because I couldnt get it to start for 2 weeks.
Old Mar 31, 2012 | 12:42 PM
foodmanry's Avatar
Da Roller Coaster!
UPDATE:
Based on that I would say you need to check your crankshaft position sensor(s). One or both may be bad. Also check your ground connections. If one is bad then you'll need to fix it. If everything checks out OK then you will need to add a ground cable from your tranny (as close to CPK as possible) to the negative terminal on your battery. Use a 2 or 4 gauge wire with good connections. I picked up everything for the ground wire from Home Depot for under $10.
Old Mar 31, 2012 | 12:45 PM
ShocknAwe's Avatar
CPS ref and yea check those grounds and maybe add in a new one TO THE FRAME. dont waste your time groundings elsewhere in the engine bay
Old Mar 31, 2012 | 01:18 PM
foodmanry's Avatar
Da Roller Coaster!
I don't know...grounding to the tranny, as suggested by others, worked for me immediately. The thought process is grounding near the CPK to ensure no other electrical interference.
What's the point of grounding from the frame to the battery? Or, are you talking about grounding from the tranny to the frame?
Old Mar 31, 2012 | 08:25 PM
cmd26's Avatar
I cant get the oil leak fixed till monday hopefully it starts and I dont have to worry about that. Cps, cpk I dont even know what those are lol.
Old Mar 31, 2012 | 09:36 PM
crankshaft position sensor.
Your car IIRC has 2 CPS sensors and 1 CKPS
Old Apr 2, 2012 | 11:30 AM
cmd26's Avatar
Ok people oil leak fixed got an oil change now gettin my ac belt changed. The max starts fine im clueless. Maybe where I parked at is on an incline my car sit there for long periods sometimes 2 weeks maybe thats a factor, idk, dat @$#t kray.
Old Apr 2, 2012 | 01:26 PM
foodmanry's Avatar
Da Roller Coaster!
Give it time the hard or no start may return. Initially, mine went away for weeks at a time and came back. As it went on further it became more frequent. It took me almost 2 years to figure it out and get it fixed thanks with the help from the org.
Old Apr 2, 2012 | 02:46 PM
cmd26's Avatar
Update:
New oil pan, tensioner pulley and ac belt.
Old Apr 6, 2012 | 08:43 PM
cmd26's Avatar
Got my car back today runs great once it starts. Starts are kinda rough so Im going to change my starter. New tensioner pulley and belt were a big difference especially in the noise department, my compressor is no super quiet.
Old Apr 6, 2012 | 09:47 PM
Darkrock's Avatar
How old is the battery? This stuff happens in 3s right? What about the ground and sensors? You may want to verify the crank problem before throwing parts at it, as in CPK and CPS, along with the checking your connection to a starter before replacing it. If this was flooded with oil you may want to pull a spark plug and see if they are fouled.
Old Apr 7, 2012 | 06:57 AM
cmd26's Avatar
Battery is fine, it was never flooded with oil. Cpk, cps will be checked but from my experience it feels like the starter.
mvm062
Nov 30, 2020 09:00 AM
gustavison
Oct 4, 2015 06:50 PM
97_GXE
Sep 15, 2015 06:47 AM
ballerchris510
Sep 11, 2015 05:29 PM
conansriver
Sep 11, 2015 10:26 AM
