flashing auto light, what does it mean
Old Mar 29, 2012 | 12:11 PM
arthur glazier's Avatar
When I start the sometimes the auto ( for the trans) light on the dash flashes 10x. I have gotten error codes for hard shift but I am able to clear them. So my question is: is this some kinda code or something?
Old Mar 29, 2012 | 12:30 PM
03VQMAX's Avatar
Check your fluid level...
Old Mar 29, 2012 | 08:51 PM
Is that what it means? or are you guessing
Old Mar 29, 2012 | 08:53 PM
03VQMAX's Avatar
Did you check your fluid level?
Old Mar 30, 2012 | 07:51 AM
yes I checked the level, and it seems fine.
Old Mar 30, 2012 | 07:54 AM
Amerikaner83's Avatar
seems fine...what's the color? What's the level? How did it smell? Look under the car for any leaks.
yes it is some kind of code. I am not sure how to pull the transmission condes, if they can be done off the standard OBD-II or not...
do you notice it shifting weird? Usually you won't get any flashes of the tranny code unless it's super bad...
Old Mar 30, 2012 | 08:00 AM
Shift_Max's Avatar
Did you check the fluid level with the car running?
Old Mar 30, 2012 | 08:19 AM
Xpcgamer's Avatar
+1!
Old Mar 30, 2012 | 08:49 AM
02pearlmax's Avatar
Are all the flashes the same length? If one flash is longer than the others, take a look at FSM page AT-54 to see which code the tranny is trying to represent for you.
Old Mar 30, 2012 | 12:47 PM
I am getting DTC P0745 LINE PRESSURE SOLENOID VALVE error code, for hard shifts some times. So I did a drain and fill, for the trans about 1 month ago and was going to do another 1 soon. The drain and fill did not really helpl the problom, but it cant hurt. I am able to clear the code but after about a week it comes back. So I have not noticed the flashing (auto) light and thought it was new. I looked in the owners manuel and reads that if it flashes for for 8 sec. that thier's a problom with the trans. I have checked the level and no burt smell. I also checked the resister by the drivers strut and it was fine. All the flashes are the some length
Old Mar 30, 2012 | 01:19 PM
when you did the drain and fill, what SPECIFIC trans fluid did you use?
mvm062
Nov 30, 2020 09:00 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
Maxima30
Sep 7, 2015 06:13 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
intimidator
Sep 5, 2015 07:23 PM
