Adding Subwoofer to Bose System
Old Jan 4, 2002 | 12:28 PM
White Lightning
I have a question concerning the Bose 7 speaker system with ND woofer. I owned a 1998 Maxima previously which employed two 6X9 Bose speakers on the rear deck for handling most of the bass duties.. I find that the new system lacks the sound quality of my 1998.. The ND woofer provides alot of reverb/boom but not much defintion..
I know, what's the question? Is the system crossover sending some of the bass to the ND woofer, or all of it..? I have a couple of bazooka's and a soundstream amp from another vehicle I'd like to drop into my new max.. I'd want to use them as a replacement to the Nd woofer and disconnect the ND woofer completely.. Is this possible.? I'd get much better definition and reproduction. Has anyone tried this or something similar.. What were the results, etc... Is it possible, without having to add a seperate crossover, etc.. Will the Bose system play if the ND woofer is disconnected..?
Old Jan 4, 2002 | 12:49 PM
jhans114's Avatar
Re: Adding Subwoofer to Bose System
It has been done! Ive done it. I disconnected the POS sub that the car brings and put 2 10" JL Audio subs in a custom box. Sounds really good. Just use the signal of the amp in the trunk to connect whatever amp you plan on using to push the sub and your done. Good luck.
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
Need help
23
Oct 2, 2015 08:56 AM
A32goldylocks
Sep 2, 2015 06:39 AM
