Rattles from back brakes...I assume
Old Apr 28, 2012 | 07:29 AM
FlyByNight's Avatar
Hey guys, small issue that is annoying me. When I go over bumps I get annoying metal on metal rattles from the back of the car, but if I put my foot on the brake over bumps the rattles stop. There is no grinding and the rear rotors have even wear on them. Is it loose rear pads or something else? Maybe it needs brakes but I am just checking to see if its a common issue.
Old Apr 28, 2012 | 07:38 AM
2damax's Avatar
Do any work recently? Sounds like my megan catback before I added a couple hangers to it.
Old Apr 28, 2012 | 08:06 AM
FlyByNight's Avatar
Nothing done, its just a stock daily driver. Its also got the front end clunks and only gets 15 MPG. I think its time to dump this heap...my 99 SE was WAAAY tighter and better on gas.
Old Apr 28, 2012 | 08:48 AM
2damax's Avatar
I relate, seriously. But I know its largely due to my lack of funds to maintain the car the way I want. I say you get under your and see if rust as broken anything. Shake stuff around. Then check brakes.
Also sounds like you need a tuneup.
Old Apr 28, 2012 | 11:00 AM
shortymust23's Avatar
i had the same problem all you have to do is tighten the back calipers thats what is rattaling in the back, but the front is probably the sway bar end links or tie rod check those out
Old Apr 28, 2012 | 11:02 AM
snicklefitz's Avatar
sounds like brake shims to me my car does the same thing
Old Apr 28, 2012 | 01:34 PM
Blue Mesa's Avatar
There's a TSB out there for this issue, it involved installing a "spring retainer kit".
You might also try jacking up the car and physically trying to rattle your rear calipers. The brackets could be loose, or the pins (that the caliper slides on) could be worn out.
Old Apr 28, 2012 | 03:11 PM
FlyByNight's Avatar
Thanks for the tips, I'll take a look at it.
Old Apr 29, 2012 | 07:00 PM
jr schultz's Avatar
I had the same rear brake issue that you had. I took the brakes apart and re-greased everything not touching the rotor. The rattle went away. I anticipate having to re-grease in a few months again. We shall see.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
jds22
Sep 4, 2015 01:52 PM
Justin Kroll
Sep 2, 2015 11:06 AM
