If that's the case why do they make adjustable lower control arms for many popular vehicles. A lot of people also use them nsyc with coilovers . Or people like me running ground controls or those that just run a lowring spring
you guys actually believe that promo vid? If you can find a 3rd gen in good condition go and compare that to your beam rear. If you done believe me go look up up the difference between the B13 and B14 sentras they have identical setups to maximas.even thou its one of the better beam setups, its not good for cornering especially tight corners.
As for pictures..... nope, spectator line was WAY too far away, and not without reason, Spock didn't get close enough to get a decent shot. He also didn't take video, I can't offer any reason why he didn't that part I'm quite disappointed with....
My camera didn't have enough zoom on the standard lens to get a good pic but video would have been great. Oh well, I guess.
I did get a couple quick shots of Rochester's car and Merovi's car Saturday night while hanging out, at least.
White car
-Corrected baytown
14.964 @ 92.664 MPH
-Corrected Sealy (Drag radials)
15.461 @ 90.795 MPH
Red Car
-Corrected baytown
14.744 @ 92.444 MPH (Drag radials + Car died after the 1000 ft)
-Corrected Sealy
14.665 @ 94.937 MPH
Red car only different mods are... 6MT, LW and US Crank Pulley, and a 3" catback.
-Corrected baytown
14.964 @ 92.664 MPH
15.461 @ 90.795 MPH
Red Car
-Corrected baytown
-Corrected Sealy
14.665 @ 94.937 MPH
Actually, the Maxima rear beam does incredibly well when pushed to these limits. Always has. It's the slower speed stuff and over all DD 'feel' that sucks. But when pushed, it performs, Merovi putting down the best time was no surpise at all to me, in fact I was going to bet Rochester that Merovi would beat him, but never did.
that LW flywheel does make a difference bro... like i said, i dont really care for all these DA corrections, white car ran 14.9@92 and red car 14.7@92... yea im sure the red car makes more power and have trapped higher but im gonna have to call a spade a spade lol
Red Car
14.81 @ 92
White Car
15.2 @ 91
Doesn't look so pretty now does it?
OMG, Tuner.
You caught me adding Liquid Schwartz to the G. Dammit.
Nice pictures you took Saturday night. Looking at them, I'm thinking I got at least 1 or 2 seconds off my runs by virtue of the how shiny my car is. What with the low wind resistance and all...
So much polish.
You caught me adding Liquid Schwartz to the G. Dammit.Nice pictures you took Saturday night. Looking at them, I'm thinking I got at least 1 or 2 seconds off my runs by virtue of the how shiny my car is. What with the low wind resistance and all...
So much polish.
Power of the Schwartz
Yeah that car is ridiculously shiny. In and out. Showroom.
Honestly looking at times and progression through the day, we were all about as equal as it gets. Considering the difference in the cars, and their condition/mods, that's pretty impressive to consider. And further illustrates the Driver's vs. cars, as we all have the same experience.
Regarding the cars though, Merovi should post his mod list. He went up against a stock '03 G35 Sedan with a broken RSB link and new summer tires, and a stock '12 G37 Sedan with bald tires.
With his modifications, his times are right where I'd expect in comparison to the G's. I was impressed almost equally with Rochester's G37 sedan. Considering the time of 46.xx was just the beginning of what that car is capable of on the track once you shut off trac control. Nevermind his bald tire factor.
Both cars are using the same intake, maf, obx headers and same wheels.... even the same lights and same other stuff too the more I think about it
And when I say same... I literally mean I took the part off of the red car and put it on the white one
BTW the 6MT LW flywheel is 3lbs lighter than a stock 5MT flywheel... And the pulley is what... like 1-2lbs lighter?
So I saved 5lbs off of the crank... A decent difference but not 6MPH..... But combined w/ tranny and 3" catback.... Hrmmm....
Also I got the same 60's on all of my best runs... low 2.3s (2.31, 2.33) in the white car, high 2.2s (2.29s) in the red.
the G37 with some small suspension mods, springs, struts, and camber adjustments, it can be a pretty quick car.
All of my best runs in the red car have been cursed.
Limp mode on the 14.81 run
And when I was gettin the 09 maxima @ the track I missed 3rd gear.
BRB lemme look up the 1/8th miles, it's like a .3 difference.
the white car has a HF-Cat like the red car did.
also you just said 2.3 in the white car n 2.2 in the red car which can easily be that 1mph you picked up in the ET... this a car with a 3" and the other without
i get what you are saying theoretically, but thats not a good way to judge the mods... the LWFW causes the car to rev faster so being 3lbs lighter in the 5MT still doesnt have the same effect as if the 5MT had a LWFW, that would be like saying if a honda motor was lighter then it should perform the same as the VQ30 or 35... when there is more variables to take into consideration, so while its only a 3lb difference the mass weight it lifts causing the car to rev faster is a far more superior difference...
The best 60 ft's in the cars do not differ more than 5 hundreths (.05).
Also guess what's coming up.... a dyno!
how is his 1/8th mile in his 3.0 help you guess a time for ur auto 3.5 with different mods???
NWP Engineering Phenolic Intake Spacers
NWP Engineering VIAS-Delete Block-off Plate
NWP Engineering Torque-Link Connector
Frankencar Short-ram Mid-pipe Air Intake
Apexi Pop-Charger
Unorthodox Racing lightweight Crank Pulley
Cattman uneven length Y-Pipe
Cattman 2.5" cat-back
Gutted pre-cats w/O2 Sim
Energy Suspension Torque Mount Bushings
Energy Suspension Subframe Bushings
Energy Suspension Lower Control Arm Bushings
Energy Suspension Shifter Bushings
Energy Suspension Front Sway-bar Bushings
Sub-frame Collars
Tokico HP Blue Stuts front and rear
MOOG Front Strut Mounts
MOOG Front Sway-bar End-links
MOOG Ball Joints
MOOG Outer Tie-rod Ends
Free Short-throw Shifter modification
Racingline Front-Strut Tower Brace
Stillen Rear-Strut Tower Brace
Progress Rear Sway Bar
Throttle-body coolant bypass
Centric Rotors
Hawk HPS Pads
LED lighting (parking lights, rear plate, courtesy lights, dome lights, map lights, vanity lights, gauge cluster, trunk light)
Leather Boot on the Emergency Brake handle
Lots of engine-bay bling...
Yup, stock car for sure
I don't get your comparison, but I understand what you mean.... 5lbs off of a crank is somewhat of a difference, I had to launch around 3500 on the track w/ street tires vs 2100-2200 when I went from 5mt to 6mt.
there is no comparison, you made it a comparison, so if im to go with your comparison im simply saying you are being biased between cars... you wanted the white car to get similar times as the red one with significantly less mods and worse 60'...
TEIN Coilovers
Apexi Pop-Charger
Sub-frame Collars
MOOG Ball Joints
Centric Rotors
Hawk HPS Pads
Apexi Pop-Charger
Sub-frame Collars
MOOG Ball Joints
Centric Rotors
Hawk HPS Pads
#2 i dont count brake pads a mod lol... the only good thing about hawk pads is the little to no brake dust left on your wheel after braking but thats definately not a "mod" lmao
If I can find something even partially equal locally (within an hour or two), I'm in. This was a lot of fun and I want to do it again.
I cannot wait to get the coilovers, sway bar link, camber arms, etc on this car and go again. No doubt it will be night and day
OHHHHH. AND here's Proof that ROCHESTER actually does more than clean his car! Gettin' Greasy Under the Hood
you know asking him that is like me asking chester what 1/4 times he ran in his G so i have an idea what my DEK runs right??? lol... you guys dont even have the same engine or chassis cars lol... you dont thinkg the motor and the weight of the cars would make the times significantly different and 0 comparison factors???
you can say all you want and what you want but fact of the matter is, both cars are similar if not the white car gets the edge for being faster.. make all kinds of theoretical assumption you want, pick and pull all the extreme throughout the run all you want... the fact of the matter is the white car trapped 1mph less than the red car with significantly less mods... and you are dissapointed in that??? id be more dissapointed with the red car
I'm just saying the white car is a bit slower than I thought it would be.
We'll see what it dynos....
CHOCOLATESTRAWWWWW!!!!!!!!!
I think you're missing the point.... on the 14.81 run the red car C O A S T E D for 400ft, the 1000 ft trap speed was lower than every other time I've ran so I'm assuming for at least 320 ft the red car was without power.
my auto DEK trapped 93mph with just intake and EVOII catback lol and constant 91-92mph
@Hustle Wife setting dat ting we spoke bout up tonight when she gets home.
@Aackshun where does the shorter control arm bolts go on the 97 they all pretty much work but i know theres a different length for summin?
@Crusher do you still have that brake bracket diagram you posted awhile ago?
@ 4th Gen section yall loosers making me have to struggle
hey aacksun what did you run in the 1/8
vs
hey aackshun what did you run in the 1/8th mile so i have an idea what to expect is another
So I'm guessing you have all the paper work ready and what
Exactly is the down payment... I may jump on this if you promise to keep it in all seriousness
