Can anyone tell me what wrong?
Old May 11, 2012 | 05:59 PM
ezkill89's Avatar
I have a 2000 nissan maxima. Well this is what happens, I might drive it a bit agressive or in high heat and my car starts sticking in 2nd gear and does not want to go past that BUT if I shut off the car while I'm driving and restart the car the problems gone. This to me it feels like its a mechanical problem I just wanted to see if anyone else has had this problem with there 5th gen max. Because everyone tells me that the tranny is good so is the motor but noone can really figure out what the problem is unless its happening, can this maybe be a sensor going bad?
Old May 11, 2012 | 09:36 PM
Coupedncal's Avatar
I think i know what's causing this problem. You are driving with three wheels and your fourth wheel is dragging in front of the car. Don't believe me? Look at the picture you have posted. One of the rims is sitting in front of the car. How do you expect the car to run smoothly this way?
Old May 11, 2012 | 10:18 PM
TunerMaxima3000's Avatar
Mechanical? No, not likely.
Get a transmission flush and/or tranny inspection done by a reputable shop. This will test line pressures, etc.
Old May 11, 2012 | 10:27 PM
nsnrider's Avatar
sticking solenoid?
possible bad transmission computer?
electrical problem?
bad ground?
just to name a few possibilities.
Old May 13, 2012 | 11:01 AM
ajahearn's Avatar
The 02 service manual says for No up shift from D2 to D3 to check the following:
1) park/neutral position switch
2) control cable adjustment
3) shift solenoid valve b
4) control valve assembly
5) vehicle speed sensor
Given that shutting off the car seems to resolve the problem I would start with #3. Since this is the 02 manual I don't know how much applies.
Old May 13, 2012 | 07:51 PM
^It's the same transmission but a different speed sensor and throttle set up. So there are differences in those electrical regards.
The physical transmission is the same (auto)
Old May 14, 2012 | 02:41 PM
Child_uv_KoRn's Avatar
Bad *** Newb
It was always the solenoids in the 4th gen, I imagine there's a good chance some of that has carried over
Forge277
Jun 13, 2016 09:26 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
pears
Sep 18, 2015 05:25 AM
