longer wired o2 sensors?? does it exists?
Old May 21, 2012 | 05:56 AM
Grand_hustle17's Avatar
http://forums.maxima.org/all-motor/6...ml#post8481463
Old May 21, 2012 | 06:01 AM
cjones450's Avatar
when i bought my car from a member on here he extened the tires to keep them from touching the OBX headers thats the only thing ive seen
Old May 21, 2012 | 06:04 AM
i know pep boys have em as an option (a very selected few) but kinda expensive so i know they exist, just dont know where else to find em...
Old May 21, 2012 | 06:13 AM
phatboislim's Avatar
ebay?
Old May 21, 2012 | 06:26 AM
longest one i found is 24.4" for the primary rear... not sure if i need any longer..
Old May 21, 2012 | 07:30 AM
cjandura's Avatar
I know you can get extension harness for $24 each but easier to buy the universal ones and use good butt splice connectors splice them to the orignal o2 wires off the old sensor
Old May 21, 2012 | 07:36 AM
CustomLowz's Avatar
I couldn't find one either... What I did was make a custom extension for my 02 sensor (on the engine side for bank 1 sensor 1 (under the firewall). I bought some high temp wire and took a bad sensor and disassembled the plug. I soldered the wires onto the pins from the bad plug, and put all back together. Made everything plug-n-play, and since i did that Ive put about 2k miles onto the car with no CEL's. Before (when i had the O2 wire extended) i couldn't go past 40 miles without the light.
Old May 21, 2012 | 07:45 AM
thats exactly why i dont want to go through, the extening wires crap... i dont have a solder gun neither... if anything i might just buy the extenstion... how good do those work???
Old May 21, 2012 | 07:58 AM
cjandura's Avatar
O2 extenders
casperselectronics.com
Old May 21, 2012 | 08:17 AM
02whitemaximase's Avatar
Are you needing this for a header install?
Old May 21, 2012 | 08:41 AM
headers already installed.. i always had a bad primary for the rear and the wire back there now is damaged because we stretched it...
Old May 21, 2012 | 08:43 AM
but instead of doing the extension i just wanna buy a longer bank 1 sensor 1 o2 sensor... the reason im a lil skeptical on the extention is because the connector piece doesnt look similar to the way the connector is on the o2 sensor
Old May 21, 2012 | 08:57 AM
CustomLowz's Avatar
hey, whatever you want... I just made myself an extension, leaving the O2 sensor alone. Its all plug and play, just like the link above, but I made it myself instead of buying it.
Old May 21, 2012 | 09:10 AM
not that im not up for trying that... just dont have a solder gun and wanna do it the easiest way possibly, even if i have to spend the lil extra $$$
Old May 21, 2012 | 09:13 AM
CustomLowz's Avatar
understandable, I would have bought the extension if I had found it before I made my own.
Old Jun 5, 2012 | 12:44 PM
REDL1NE's Avatar
So extension(part number 109247) is a fit to the current 02 connector?
Link:
http://www.casperselectronics.com/st...948169946649e7
wyobbagy
Jan 3, 2023 12:03 PM
bbsitum
Sep 6, 2019 07:31 PM
conansriver
Sep 11, 2015 10:26 AM
