3rd gear crunch
Old May 23, 2012 | 08:13 AM
  #41
Grand_hustle17's Avatar
Originally Posted by 2000_MAXIMA_KING
I have the redline shockproof in my trans, previous owner had it put in when shop did the clutch. I was confused when I first seen it since it's a minty color. Maybe you should try it, lots have had good results with it. I still crunch sometimes though but for a 20 year old trans and one thats known for crunching in almost every gear, its pretty damn guuuddd.
o.k... im going to try getting my rad support fixed 1st as its rusted out and with the front motor mount being of no effect really hopefully that helps the crunch... i have an appointment this saturday to get it fixed, after which i will try the gear oil n hopefully that gets it done... the car tends to vibrate a lil harder since the header install
  #42
aackshun's Avatar
Originally Posted by cjandura
6mt swap
+1
Originally Posted by essential1
You can get gl4 from Napa. It's in a white 4 quart bottle with a teal/green lable if I'm not mistaken.
It's not the world's greatest stuff though, affordable and it's not bad.
Gotcha, mines dont crunch at all on down shift and ever so random on upshifts... now that i found the vendors here ill justgo buy 2 qts maybe
That's what my car is doing, I will probably end up trying the MT-85 when I re-do the seals (so it won't leak out) whenever I buy a LWFW.
Old May 23, 2012 | 08:20 AM
  #43
yea i suspect there is some kinda leak in mines... i wont do a 6mt for multiple reasons...
Clutches n Flywheels are too expensive, i would at least need an LSD because that what i have now thats pretty pricey n like me n you txted the other day, the axles are obsolete
Old May 23, 2012 | 08:22 AM
  #44
aackshun's Avatar
Motor mounts will not fix a gear crunch issue btw.
Only the wobble or bucking that's felt while changing gears.
Old May 23, 2012 | 08:26 AM
  #45
cjandura's Avatar
could that gear crunch be something else caused by the mounts not holding the engine proper during shift movement? really your torque mounts arnt doing anything right now because there not attached to the car so i know you have alot of movement
Old May 23, 2012 | 08:32 AM
  #46
aackshun's Avatar
Eh?
Check the new ghustle thread for response.
Old May 23, 2012 | 08:34 AM
  #47
aackshun's Avatar
My engine only moves a few MM's because of the ghetto Poly front moutn I have.
I have an aluminum rear, new transmission and tq mount and poly filled front mount.....
You would need some radical engine movement on a 5mt to cause a wacky angle or half shift to cause a grind while putting it into gear.
Old May 23, 2012 | 08:45 AM
  #48
exactly... i understand what aackshun is saying on the mounts barely moving... but my crossmember is only being held in with 2 bolts right now... the 2 in the rear so im about 100000% sure that the motor has more movement than he thinks... and like i said it doesnt crunch all the time un upshifts and doesnt do it at all ever on downshifts
Eh?
o.k...
Old May 23, 2012 | 11:07 PM
  #49
VisciousMo's Avatar
You sure about that?
3/4 Poly mounts. visibly intact tranny mount. My only option is to replace the tranny mount hoping to reduce that woble. You drove my car too with and felt it.
I'm really thinking about going back to Redline oil, I felt it was smoother than my current AMSOIL setup.
edit: heading to Houston late night wednesday. meetup for food?
Old May 24, 2012 | 04:54 AM
  #50
The locals here in MD go with penzoil syncromesh, they said the trans feel notchy in the cold with redline but with syncromesh the shifts are noticeably smoother all year round..... I believe that's what all the 5.5's here use.... One still on his original transr n beats on it weekly
Old May 24, 2012 | 09:19 AM
  #51
aackshun's Avatar
I forgot what it was.
My car just needs oil, gear oil leak steady keeps the oil level low
I'll fix it whenever I get me hands on a LWFW.
Penzoil Synchromesh eh? Worth a shot. Cheaper than the good 'ish I'll give it a try.
Old May 24, 2012 | 10:32 AM
  #52
VisciousMo's Avatar
This ?
http://m.advanceautoparts.com/mt/sho...llReviews=true
Old May 24, 2012 | 10:33 AM
  #53
VisciousMo's Avatar
And , it dosent specify its GL-4, or maybe it does . I'm on my phone
Old May 24, 2012 | 10:36 AM
  #54
aackshun's Avatar
Chrisman get off of your phone
I did some googling, it's a GL4 80W, winning so far...
But I like le price, I can't go wrong there. Perfect white car territory, I guess I'm going full Penzoil in that car now
(Penzoil Platinum is the next oil change).
Old May 24, 2012 | 11:03 AM
  #55
Cutler's Avatar
I know alot of the Mazda guys went to Ford Motorcraft synthetic for the 6-speeds....
Otherwise....check out www.ogracing.com.....good people who actually race cars
Old May 24, 2012 | 12:35 PM
  #56
VisciousMo's Avatar
you doing it soon ?
If we don't race our cars...why mention?
Old May 24, 2012 | 02:02 PM
  #57
dfj240's Avatar
Because people who actually race their cars usually have a good idea of what to use when it comes to stuff like that. They use all different kinds of fluids through their engines and transmissions. And they abuse their cars too, so if it works well for them, then chances are it will work brilliantly for those of us who don't run our cars at the track.
Personally, I used GM Syncromesh in a few track cars and was very pleased. I've used Redline too, and I can't really make a difference between the two. This is, of course, personal preference.
-Nathan
Old May 24, 2012 | 02:58 PM
  #58
aackshun's Avatar
you doing it soon ?
Yeah sometime next week, it's about that time.
The transmission tho? meh who knows.
and you got owned.
Old May 24, 2012 | 03:15 PM
  #59
VisciousMo's Avatar
-Nathan
****, you got me.
and you got owned.
Don't make me use the image I recently acquired!
Old May 25, 2012 | 09:45 AM
  #60
IMO just because a race car uses something doesnt means its suitable for a daily but i understand what u guys are saying... penzoil synchromesh is what im going to go with... and ill order some asmoil for the future
Old May 25, 2012 | 10:57 AM
  #61
aackshun's Avatar
You.
A.
Hoe.
Using photos of me in Highschool as leverage, why i'd outtaa
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
