How to remove a 2002 Nissan Maxima SE Dash?
Old May 25, 2012 | 07:09 PM
EvoTillIDie's Avatar
Yeah..I'd really like to know how to remove it for a swap I have planned
Old May 25, 2012 | 08:29 PM
Nexus67's Avatar
I might be wrong but I actually don't think there's a write-up for this so hopefully this thread will eventually grow and evolve into a sticky.
Subscribed.
Old May 26, 2012 | 01:09 AM
RR5's Avatar
RR5
To start, check the FSM. http://www.nicoclub.com/FSM/maxima/
Old May 26, 2012 | 06:48 AM
Maybe this might help but uhh
AT.pdf 05-Feb-2010 17:59 6.6M
AX.pdf 05-Feb-2010 17:59 427K
BR.pdf 05-Feb-2010 17:59 2.0M
BT.pdf 05-Feb-2010 17:59 3.0M
CL.pdf 05-Feb-2010 17:59 325K
EC.pdf 05-Feb-2010 17:59 8.2M
EL.pdf 05-Feb-2010 17:59 13M
EM.pdf 05-Feb-2010 17:59 2.9M
FE.pdf 05-Feb-2010 17:59 246K
Foldout.pdf 05-Feb-2010 17:59 167K
GI.pdf 05-Feb-2010 17:59 915K
HA.pdf 05-Feb-2010 17:59 4.8M
IDX.pdf 05-Feb-2010 17:59 35K
LC.pdf 05-Feb-2010 17:59 715K
MA.pdf 05-Feb-2010 17:59 1.4M
MT.pdf 05-Feb-2010 17:59 1.8M
RS.pdf 05-Feb-2010 17:59 1.1M
SC.pdf 05-Feb-2010 17:59 559K
ST.pdf 05-Feb-2010 17:59 612K
SU.pdf 05-Feb-2010 17:59 645K
fwd.pdf
^^^^^ is this?
Old May 26, 2012 | 06:58 AM
OK so searching around & updating my Adobe Reader *this is a MUST for a better view of the pdf* I found out that "BT" means body & trim...the removal of the dash instructions are in here starting at page 28...I was hoping there would be pictures so I can understand it much better but I guess when I pick my shell up this will be the first project I do & make a sticky for it....*Hopefully someone else saves me the trouble & do it first* lol
Old May 26, 2012 | 11:06 AM
Froggmann's Avatar
Check this thread: Odd A/C Problem there's no write-up but you can see what is involved wiht the dash removal.
there's also a thread by dennismik where he removed the dash. Yes I know these were 4th gen threads but I have found all the engineering is the same.
Essentially, you have fasteners on both sides of the footwells, 4 in the center cluster and 2 in the dash. You will need to remove the center console to get the dash completely out. Be sure to pull the neg side of the battery for at least 20 minutes before dealing with the air bag above the glove compartment.
Old May 26, 2012 | 11:28 AM
DennisMik's Avatar
I removed the dash on my 97 4th gen and did a writeup. I also have a 2000 5th gen and have looked at it a little bit to try and compare it to the 97. There definitely are differences but I consider them to be small. The glove box is held in a little different, so is the radio and the panel under the steering column.
If you are interested, here is the link to the thread I made.
http://forums.maxima.org/4th-generat...dashboard.html
xUNIxPanther
Aug 27, 2015 10:09 PM
District
Aug 15, 2015 08:23 PM
13Maximasv
Aug 7, 2015 10:56 AM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
