Loose sidemarkers
Old May 30, 2012 | 12:21 PM
CWolfSE's Avatar
Loose sidemarkers
Just installed my aftermarket sidemarkers and they are wobbly/loose, kinda frustrating. did anyone else have this problem?.. Is there a way to tighten them like the OEM ones?
Also hurt the paint a little bit in the corners ....how can I hide that
Old May 30, 2012 | 12:32 PM
Rochester's Avatar
Fronts or rears? My guess is the fronts, in which case you should know the fronts are specifically designed for one side or the other. Left-side marker, and right-side marker.
Old May 30, 2012 | 01:08 PM
CWolfSE's Avatar
Rears! haha 50/50. Fronts were no problem, just wobbly and loose back ones. It's not a problem, I would just like to fix them tight like stock
Old May 30, 2012 | 01:22 PM
Rochester's Avatar
In that case, I have no advice. When I replaced mine, I used DEPO lenses, and they clipped in nice and firm. So IDK what to tell you.
Old May 30, 2012 | 01:55 PM
CWolfSE's Avatar
[QUOTE=Rochester;8493441]In that case, I have no advice. When I replaced mine, I used DEPO lenses, and they clipped in nice and firm. So IDK what to tell you.
What the hell!?.. I got DEPO too. They aren't firm. Maybe I'll email them and see what's the issue is
Old May 30, 2012 | 02:22 PM
CWolfSE's Avatar
looks nice, just loose. And then what i did to the paint... also chipped it a little
Old May 31, 2012 | 12:33 AM
02pearlmax's Avatar
Has your car been in an accident? My clear side markers used to fit just fine, but then I got rear ended and the insurance company gave me a non-Nissan replacement bumper. Now one sidemarker fits extremely tight while the other is a tad loose. Not much to do about it except wedge some foam or something to keep it from moving around.
As far as your paint scratches, go to your local Nissan dealer and get a bottle of touch up paint matched to the color code of your car for about $15-$20. It's a bit expensive but it will come in handy for other things down the road.
Old May 31, 2012 | 04:55 AM
CWolfSE's Avatar
The stock ones fit fine. Nice and tight. So I don't think it's the bumber, good suggestion though. And thank you for The paint advice I'll do that asap
Old May 31, 2012 | 05:33 AM
Rochester's Avatar
That fitment isn't right at all. Weird. Also, you got the clear lenses, whereas I was using the smoked ones... not that it should matter. I would contact the seller or DEPO directly and see if you can get an answer. You'll probably have to remove the lens again to access the part number.
As for the damage, what's done is done, but I removed the rears by working the front end of the lens, not the rear.
Old May 31, 2012 | 09:16 AM
CWolfSE's Avatar
I emailed the seller to no response.. Yet. Hopefully he'll answer. And are you suing it doesn't fit right because it's so far away from the rear side ? My luck I get defective sidemarkers.
And also the light bulb never goes on, no matter what lights I turn on, they stay off. Is that normal?
Old May 31, 2012 | 09:26 AM
TunerMaxima3000's Avatar
That's only normal becuase those little #194 bulbs burn out so fast.
Old May 31, 2012 | 09:36 AM
Rochester's Avatar
And are you suing it doesn't fit right because it's so far away from the rear side?
Yep. Search online and find pics. Wait... here's one.
Well no, of course that's not normal. Light bulbs should light up. That's what they do.
If it's an incandescent bulb, then it's blown. If it's an LED bulb, try turning it around in the socket. Most LED wedge bulbs have a specific polarity.
Old May 31, 2012 | 09:42 AM
Prophecy99's Avatar
mine rears are loose, allways have been, you can slightly move them around, and it was a concern at first but its not going anywhere if it is properly installed.
the key here is ..... cheap aftermarket crap....
Old May 31, 2012 | 10:16 AM
DennisMik's Avatar
The reason you damaged the paint is because you pried out the original from the wrong end. You should remove the light assembly from the end that is towards the front of the car.
Old May 31, 2012 | 11:26 AM
CWolfSE's Avatar
Is it common that the backs burn out quicker because the front ones are fine.. I'll just replace them. Maybe I'll post a picture of the light I have
Old May 31, 2012 | 11:28 AM
CWolfSE's Avatar
Yeah I realized that after I destroyed the corner and the paint
Old May 31, 2012 | 11:31 AM
CWolfSE's Avatar
I didn't even aim for saving money on cheap crap though, I thought DEPO was up there in quality
Old Jun 1, 2012 | 10:16 AM
Prophecy99's Avatar
in reality depo is still an aftermarket company, and you will always have little quirks with fitment from anyone but OEM.
Old Jun 1, 2012 | 10:39 AM
02pearlmax's Avatar
^This. Aftermarket is aftermarket no matter how much you pay. Same goes with pretty much anything else you can buy for your car.
Old Jun 1, 2012 | 12:15 PM
CWolfSE's Avatar
Ok... Well my DEPO front sidemarkers fit perfectly, they are an exact replica of stocks, just clear. They also came with an extra set of bulbs, which will come in handy. I just got a bad seller for the rear set, and wanted to see if I can fix the looseness, That's all
Old Feb 6, 2014 | 07:59 PM
george__'s Avatar
need help... I bought Depo clear side markers and the front fit perfect but the rear ones a tiny ~1 cm gap is this due to wrong install or bad QC?
Old Feb 7, 2014 | 10:07 AM
Prophecy99's Avatar
does you read the hole threads ^^^
anyway, yes it's normal... let it go.
Old Feb 7, 2014 | 06:56 PM
george__'s Avatar
I was hoping the OP/posters had a solution
Old Feb 8, 2014 | 09:01 AM
The_Fixer's Avatar
Issue due to person installing! Never let a Canadian slurpie slinger install parts on your cars Boys & Girls because george_ is what will happen to you!
Old Feb 8, 2014 | 01:16 PM
DOODOOCHIP's Avatar
Use lots of tape george.
Old Feb 8, 2014 | 02:12 PM
george__'s Avatar
It doesn't move just that tiny gap *GRR*
Old Feb 8, 2014 | 03:10 PM
The_Fixer's Avatar
Stop buying bootleg ebay products!this confirms it there is NOT ONE SINGLE THING you DO to your car that works right its a sign george_
Old Feb 8, 2014 | 03:17 PM
george__'s Avatar
I'm thinking the bumper could be a replacement
D Mason
Jun 21, 2016 04:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
viperboy
Sep 27, 2015 07:05 PM
Junebug1701
Sep 25, 2015 01:54 PM
BrandonCause
Sep 14, 2015 10:41 PM
