avpro company ecu repair
Old Jun 5, 2012 | 03:06 PM
xxemranxx's Avatar
i sent them my ecu and they repaired it i got it in and installed it turned the key in on position and sta509a chip broke
sent it back they want another 190 bucks to fix it
even tho they offered lifetime warranty
what should i do??
Old Jun 5, 2012 | 03:08 PM
cjandura's Avatar
Change you TB and unplug your motor mounts and try again
Old Jun 5, 2012 | 03:31 PM
memphisballer's Avatar
Make friends with a soldering iron and buy the chip yourself.
I'd be pissed right now.Maybe someone local with good soldering skills?
An electronics shop? and of course do whats mentioned above first.
Old Jun 7, 2012 | 08:44 PM
Maxatnite's Avatar
I called Avpro and asked them about your problem since I have been talking to them about a new module they are testing. He said he is still waiting for u to send the idle speed motor so they can test it to find out what is going on. He said the idle speed overloaded the ecm again and burned not just the module but a trace off the board. If the idle speed motor is not changed before you try the repaired ecm it is not covered under their warranty according to their warranty statement published on their site. He also said you told him that one of the coils tested at 33 ohms which indicates a problem with the new idle valve. They have the ecms and are waiting for u to send the idle motor as you said u would with the ecm but u did not send it. My impression is they want to get your car going but are not getting what they need from u.
Old Jun 9, 2012 | 08:06 AM
looks like your "AVPRO" rep or possible spammer has spoken.
He has also posted the same message below on two different threads.
"Just talked to a guy at Avpro and apparently they have developed a module to replace the STA509A for the idle speed and the STA508A for the active motor mounts. He said they are still testing it. It detects overload and shuts down all drive to the idle valve for 2 seconds preventing damage. He said the will be selling it separate from the repair they do. I may replace mine before I have a P505 code. The ecu will still throw the code if the iacv goes bad."
mkaresh
Mar 12, 2018 06:48 PM
gigabyte
Jan 6, 2017 06:05 PM
MichMaxFan
Sep 30, 2015 09:18 AM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
