Radiator cooling fan question
Old Jun 26, 2012 | 04:41 AM
maxs4life's Avatar
While driving with my AC I notice that my car overheats. I took it to a mechanic and i was told that my the cooling fan Motor was bad. Im not looking to spend crazy money, i just want to get whats necessary to fix this problem. Im looking on ebay and i see all these universal fans. I have an 03 maxima. I believe its the passenger side fan thats bad. ANy recommedations...
Old Jun 26, 2012 | 07:38 AM
njmaxseltd's Avatar
The fan motor's bad, replace it as it's necessary to fix the problem.
Google much??
Rockauto.com $41.89 and it's in stock.
Old Jun 26, 2012 | 07:53 AM
maxs4life's Avatar
how about one of them ebay fans... are they ok?
Old Jun 26, 2012 | 08:00 PM
cabernet's Avatar
I don't know about the 2K3 but on my 2K it was easier to replace the entire shroud and 2 fan assembly for about $100 on Amazon. Looked like replacing just the motor was a lot of work and the other fan might go out soon also.
On the 2K both fans should be running with the AC on. If one isn't running then you have a bad fan motor.
Old Jun 27, 2012 | 09:02 PM
DennisMik's Avatar
Don't ever buy a universal fan for a Maxima. The maxima fans are 2 speed, the universals are not.
Old Jun 27, 2012 | 09:13 PM
foodmanry's Avatar
Da Roller Coaster!
It isn't that much work to replace the motor....if you are replacing the entire shroud there is only one more step to replace the motor versus the entire shroud.
Old Jun 28, 2012 | 07:37 PM
DjHackStyle's Avatar
if you are 100% sure ur fans are bad, just replace both, go to rockauto.com and they're like $100 for both, if you go further than that to fix your cooling issue, get the tyc radiator from rockauto and go to nissan dealer to get a thermostat only use an oem thermostat, trust me on that.
captchaos
Mar 15, 2016 12:18 PM
Smackasmith
Feb 1, 2016 12:40 AM
asianstyle
Sep 10, 2015 11:30 AM
videomano
Sep 8, 2015 03:28 PM
