bad mpg on a 2001 maxima
Old Jul 2, 2012 | 08:40 AM
  #41
TunerMaxima3000's Avatar
The knock sensor basically controls the timing of detonation in the cylinders. If the KS detects knock, it will retard the timing, if it is not working right and not giving the car the proper signals, the car will not run at its peak efficiency. Car not running at its peak efficiency=low gas mileage. Proper KS operation=peak efficiency=good gas mileage.
^^That's a giant OVERsimplicifcation of how it works, but the basic premise is right.
You're on the right track for sure here.
The Knock sensor is basically a microphone that listens to the engine. If it hears a Knock (detonation) in the engine, it retards timing.
One other thing it does that people don't really talk about is the adding of fuel.
Rich conditions are a 'failsafe' for engines. Extra fuel cools the intake charge which lowers combustion temperatures which removes the main ingredients for detonation.
Hence, retarded timing and more fuel = no more detonation
A failing or failed Knock Sensor can do 2 things:
1. Could be showing the engine a knock condition, which results in more fuel and retarded timing
2. Could be reading nothing at all, or 'shorted', which will result in a Default 'failsafe' timing Map. This is basically a much, much less noticable "limp mode" for the car.
You won't really notice a loss of power, especially if you never had it to start with. Most often the ONLY thing people notice is increased fuel mileage.
(When the Knock Sensor is working properly, it allows the engine to run near peak efficiancy because it can run close to the point where it Detonates. When working accurately, the knock sensor can tell exactly which cylinder is/was detonating and adjust ONLY that cylinder in millionths of a second. In short, it's seamless. Without intriquite datalogging you wouldn't even see it while monitoring the sensor.)
Old Jul 2, 2012 | 08:47 AM
  #42
He would be getting terrible performance, though, if the knock sensor is to blame (although he could have more than one problem).
covered this above.
Until the maf is replaced, there's no point in theorizing anything. Idk why people think you can test them. It just doesn't work that way unless you were incredibly analytical and could compare directly to another car operating under the same parameters as yours.
Agree. OP, My vote is also to replace your MAFS with an OEM unit. I stress OEM unit.
Old Jul 2, 2012 | 02:32 PM
  #43
noahrexion's Avatar
Are you guys buying your OEM MAFS from courtesy parts? They are $400!
Old Jul 2, 2012 | 06:29 PM
  #44
dfj240's Avatar
I bought my 2001 MAFS from the local dealer close to my shop. With my shop discount, it was ~$85-$90. Without the discount, it should be around $110-120. The 2002-2003 MAFS's are pretty pricey. The only difference is the 2002-2003 have the IAT built in, in the form of a thermistor. The thermistor can be installed on the 2001 without much trouble.
-Nathan
Old Jul 2, 2012 | 06:47 PM
  #45
I'd suggest buying a replacement thermistor separately, and buying a 2000/2001 MAFS suggested.
You should change that Thermistor for a new one though given your issues. They're not known for failing but they're super cheap. I forget where but someone found a replacement for it under $20.
You can also find MAFS's in the junkyard, go in and grab a couple. Ihave a couple in my basement.
Just remember this is rolling the dice REALLY BAD. if you don't get at least 2 or 3 don't bother. And try everyone of them. This is if you want to cheap out.
Personally with that crappy mileage, I'd spend the money on a new MAFS that is OEM, just find a good deal on it.
Old Jul 2, 2012 | 06:50 PM
  #46
crazy97's Avatar
I dont know what it is but everytime I see a thread like this(Low mpg) its a an east coaster.. Ny or Philly. There must be something in the gas out there.
Old Jul 2, 2012 | 07:49 PM
  #47
dfj240's Avatar
I bought a new thermistor when I got mine too. The thermistor itself was only 82 cents. Shipping was $7.20 or something like that. Lol. Still super cheap, and you can call around to local electronic parts suppliers and the like and might be able to get it without having to worry about shipping.
And Tuner's right, I would spend the money on a new one. Even if you buy 3 at the salvage yard, there's no guarantee they will work, and you can't take them back for a replacement if they don't. Definitely buy OEM new.
-Nathan
-Nathan
Old Jul 3, 2012 | 10:33 AM
  #48
Flanker84's Avatar
I got a question about this thread.
I have read the important parts about the different kind of sensors (KS, MAF, O2, etc) and I want to know if exists the possibility of got a bad sensor but without a "Check Engine" light or that my scanner doesn't show it. Also I got a crappy gas mileage of 12 MPG (city) with temperatures above 100 Fahrenheit but in Highway I got a gas mileage of 24 Mpg with almost the same temperatures!
Also I changed the fuel filter, IACV, spark plugs and I'm using mineral oil (15w-40) with a High flow Air filter, BPI flowstack and a short ram intake.
Can it be that something is wrong with my car or it's just the damn weather that it's killing my gas mileage?!
Thanks.
Old Jul 3, 2012 | 10:44 AM
  #49
dfj240's Avatar
Sounds like a heavy foot more than anything to me.. Also, why are you using 15w-40? That some pretty heavy oil for a 3.0 gasoline engine. 10w-30 would be the heaviest I put in my car, but I normally go with 5w-20, or 5w-30.
To answer your question though, yes, it's possible for a sensor to be causing a problem and not illuminate the MIL. However, if you continue running the car then eventually the part is bound to fail to the point that the MIL lights up.
-Nathan
Old Jul 3, 2012 | 10:52 AM
  #50
Child_uv_KoRn's Avatar
Bad *** Newb
It's impossible to burn that much with a 3.0. I have the heaviest foot of anyone I know and I can still manage about 17 mpg mixed driving (3.5L). My rule of thumb is if you're not at redline, then why shift?
Old Jul 3, 2012 | 11:03 AM
  #51
Flanker84's Avatar
-Nathan
I try to drive in a easy and relaxed way, and try to use some Hypermiler techniques but the sad part it's that the traffic lights in my city aren't synchronized and you do a lot of stop and go. Now that I think about it maybe that's the main cause of my poor gas mileage in city.
I use 15w-40 oil because the summer weather in my city can kill your engine (when sometimes the temperatures can reach the 120 Fahrenheit degrees). I'm going to use 10W-30 Synthetic oil in the next change.
Also, I'll keep an eye over my engine and check if something is wrong with that sensors. Thanks Nathan.
Old Jul 3, 2012 | 12:43 PM
  #52
dfj240's Avatar
This made me giggle.
Old Jul 3, 2012 | 12:54 PM
  #53
Galactica's Avatar
You are in Mexico. Maybe the gas sucks...just sayin... They need to get some good signal electricians like me down there to set up the signals properly.
Old Jul 3, 2012 | 01:30 PM
  #54
Flanker84's Avatar
The quality between the gas of USA and Mexico are very noticeable. Our gas it's more imperfect and the refinements processes is not the same in every facility.
Even now exists a problem with the low cost gas (Magna Sin with 87 octanes) where the engines doesn't perform in a proper way, even some people are reporting failures due to the use of this gasoline.
We got the another kind of gasoline (Premium Sin with 92 octanes) that I use in my car. And yes, it's my only choice by the moment.
And the problem with the traffic lights it's that the Traffic Department of my city it's full of ******** that doesn't know HOW to fix this. We have been trying to teach them (I work in the State Government) the proper way to synchronize the traffic lights and correct procedures for management of traffic in peak hours and the design, without promising results.
Old Jul 3, 2012 | 02:41 PM
  #55
-Nathan
This.
There's no climate on this planet that requires 15w40 in a gas engine. And heavier oil will create more friciton which = worse performance/mileage.
Not that it's your issue, but it's really foolish to run 15w40 in this engine.
Old Jul 5, 2012 | 08:04 PM
  #56
jeffny09's Avatar
sorry guys ive been very busy, but have been steadily watching my mileage go up..after changing my fuel filter, and fixing the problem that the bec filter gave me,,my miles went up from 13 mpg to 20 mpg. no im not imagining this. i tested this out the last couple days and its what im calculating. but id still like to get back some more of my mileage. is it still worth replacing the knock sensor??
Old Jul 5, 2012 | 09:23 PM
  #57
dfj240's Avatar
20 mpg average should be just about right depending on driving mixture, weather, traffic, right foot, etc. I don't think changing a knock sensor will net you much of anything in the way of mpg.
-Nathan
Old Jul 5, 2012 | 10:11 PM
  #58
DavefromCA's Avatar
Not too sure about my city mileage, id say high teens. I get about 25-26 going to see my family which is about a 710 mile round trip. There are some hills here and there, 75 mph, traffic sometimes...
...and I try not to call bs but 37 mpg? How is that possible. Its still a 3300+ pound car, 227 hp v6. Uppers 30s are what modern sub compacts are getting.
Old Jul 5, 2012 | 10:39 PM
  #59
20 mpg is about average for this engine if you drive it.
22-26 is possible but you'll have to put some work in, KS is a good start. Fuel injector flush (professional one, not the 'in a bottle' stuff), etc.
After that you're looking at breathing mods>> exhaust. Y pipe will net gains in power and fuel economy. So will a good mandrel bent catback.
And a tune would be ideal to reap full benefit and put you over 25 mpg, WITH more power
But we're talking some coin now, right/
Old Jul 5, 2012 | 11:46 PM
  #60
dfj240's Avatar
Lol. It's not bs, but the car's running state is. I've been working on a real bad bogging issue with my car, and the car runs EXTREMELY lean at random. It cruises down the highway just fine, but I can't ever try to pass anyone. I've been forced to drive it this way, as I sold my other car a little too soon. It most certainly should NOT get that kind of fuel mileage when running properly. Mine's an 02, so it should have 255 hp on tap, it feels like it's got about 55 hp. Anyways, I mainly posted for humor's sake, but in all reality, my car is really quite frustrating. Lol.
In any case, I think your estimates here are spot on as far as what to expect from a Maxima that is running properly. Definitely do not use my 5.5 gen freak of nature as a guide for an average.
-Nathan
Old Jul 6, 2012 | 05:54 AM
  #61
Also the 5.5 gets better mileage on average than the 5th gen.
HOKUSMAX
Nov 13, 2017 04:34 AM
ah2002
Mar 9, 2016 01:42 PM
District
Aug 15, 2015 08:23 PM
Bruceharrison
Aug 9, 2015 07:56 AM
wpr
Aug 5, 2015 03:28 AM
