can't raise window up on 2002 maxima
Old Jun 30, 2012 | 03:37 PM
ghawkins67's Avatar
any suggestions on how to get the window up far enough to remove the bolts from the regulator.
Old Jun 30, 2012 | 03:44 PM
ShocknAwe's Avatar
take the panel off and get a girl with small arms lol
Old Jun 30, 2012 | 03:48 PM
user name001's Avatar
what do u mean lol , unbolt the regulator first, then u can get some movement to get ur had in there to remove the glass from the reg.
Old Jun 30, 2012 | 08:58 PM
Maxed Outy's Avatar
Mine was stuck all the way down, I was able to get a box wrench on the left one, the right one I was able to get to by taking out the speaker and using a box wrench again. It was very small turns at a time and took awhile but got it.
Hard reach on that right side one though, have a magnet handy for when you drop the wrench.
If you just can't get it cut the wires on the regulator then it should freewheel. I assume you motor died, you can get the motor and reg together for not much more than the cost of the motor alone.
Also if you unbolt the regulator and motor that should give you a couple more inches of movement.
Old Jul 1, 2012 | 03:55 PM
ateick's Avatar
^+1. Save yourself time - cut the cable and replace everything.
fastcarny
May 18, 2020 10:40 AM
Nintensity
Aug 13, 2015 05:41 PM
fastcarny
Aug 12, 2015 03:50 PM
yat70458
Aug 3, 2015 01:16 PM
