Mystery Problem Eludes Mechanics
#41
I'm not sure why you would need to do an ECU update if you are replacing with OEM. I mean it should be sending the same voltages and pulse info. Maybe if it is aftermarket though.
#42
I'm not sure that is correct. When mine went bad and I changed it, I didn't take it to the dealer for an ECU update and everything has been fine.
#44
dont know if its been asked but hows your fuel pressure
#48
i would check the grounds. Actually, I would add an extra ground from the body to the engine and at the same time clean the two grounds by the engine oil fill cap.
I had a problem that took me weeks to resolve. Intermittent stuttering. Ended up being two bad grounds by the engine fill cap. That was a long experience.
#49
After reading this entire thread, based on previous experience with 3rd and 4th gen Maximas, I refuse to believe the problem is anything other than a bad MAF. Every single little detail is yelling out MAF. And if its not the MAF, its at least related. Bad harness, yanked wire or similar. Have you checked continuity from MAF harness to ECU harness?
#50
And for the people suggesting ground issue. If it were ground, it would have starting issues not revving issues. I had a disconnected ground once after an engine swap and that was the problem. Not limiting me to 1700rpms only hard starts
#51
DW
#52
Btw, I don't recall the op talking much about calibrating the tps other than saying that the calibration wasn't the issue. OP did you properly calibrate the TPS?
#53
I am stuck on these two things also.
#55
Im sorry i cant help solve this problem but i have a very similar problem with a 01 S.E. Recently my regular mechanic was trying to figure out why my car wouldn't run cold (literally would try to pull out of my driveway and try to get going and the car would crawl for about 20 sec before it decided to co-operate with me) after it gets warm, it doesn't like to give me any power at all without a fight not to mention if i get frustrated and try to put the pedal down the rpms stick to 3k and looses power again.
Mechanic replaced the MAF and it actually ran worse.
#56
Similarly, my 96 was running somewhat rough and wanted to stall in reverse while cold. It ran fine otherwise. I looked at the baffle and it had a crack letting air in. I duct taped it temporarily and the car now runs ultra smooth.
For both of you guys I would make sure there is no leak between the maf and the throttle body.
#57
-Nathan
#59
O2 Sensor Problems
I don't have acceleration problems, but for me, it's the O2 senor. I keep getting the Bank 1 Sensor 2 code and even after changing it, it comes back. Don't know if you guys have any ideas as to what that may be
#60
you changed the wrong one. now quit jacking this thread and post in the im new here thread
#61
OP, have you had a chance to test compression and/or back pressure/manifold vacuum? That can tell you A LOT!
-Nathan
#62
Sorry for taking so long.
I haven't had a chance to get the vacuum test BUT I did end up getting the p0430 code for a bad bank 2 precat. I don't intend to replace this part but was wondering if an o2 sim could be of use. Is it possible the precat is clogged but on its own it's causing no symptoms? once the car is warm and starts reading from the sensor associated with the clogged precat it starts freaking out the ecu?
I'd rather avoid replacing the precat. It's expensive and I'm just going to sell the car.
Any thoughts?
Any thoughts?
#63
That could be a vacuum leak. I would closely check the hose baffle between the MAF and the Throttle Body. I had a problem once where the underneath of the baffle was pinched and letting air in.
You can get new rubber pieces from the Dealers but there expensive :[
Duct and electrical tape are your friends here till you can get a good permanent fix. The more unmetered air gets in the worse its going to perform, idle, and drive overall.
#64
Any thoughts?
Any thoughts?
Seriously, have you at least looked at everything I mentioned? I'm not talking about a specific test - just a visual inspection.
03-12-2020 12:06 AM
