Car trouble again, car won't start.
My 03 Nissan Maxima had oil problems in the past and I had to get my engine replaced due to knocking in the engine. Got the engine replaced, then two weeks later the car shut off while driving. Found out it was the body control module. Replace the BCM and drove it for 3 months, now car won't turn on. Battery is good. When i go to start the car the AC is blasting when i never turned it on. Also when i take the key out the dash lights (CEL, oil, Alarm, etc) remain lit for some time. Could it be the body control module again? If i change the BCM do i need to change the immobilizer as well?
Any help would be greatly appreciated!
Wow - have you got gremlins. Before you moved, you said that you needed a new engine harness. Did that get replaced with the engine?
I really don't know what to suggest except that the part about the dash lights make me wonder if they left one of the major ground wires off.
I know man, she doesn't love me! Engine harness was never changed. Only the thing that was fixed thatI was aware of was the body control module. Sad bro, I dunno what to do!
The dashlights just started today when the car didn't start.
Great if it's the BCM again where am i supposed to find one? Where in the car is the BCM located? Is that something I can change out myself?
Also, where would i find the short-out at the ignition wiring harness? Thanks so much for your help!
Not yet, I just took out the starter to have it checked to see if it is the problem.
I think, if you try to read the error codes this won't work either. If this is the case then the problem would be localized to the ECU, you can leave the rest of the car alone.
So I have found what I believe to be the problem! As x6runner stated it was related to be Body Control Module. I got a new flip key about 3 months ago and had it programmed and it worked fine until a month ago. It seems the key was the culprit. I got the car starting and then i would try to stop and start it again and it wouldn't start with the flip key. Then I unplugged the BCM plugged it back in and tried the OEM key and it worked. It has been working for the last week now with no problem. So it seems that the BCM with not likely the aftermarket key, what a shame, it was an awesome key.
Anyhow that was the problem and it might be solved now. Hope this helps anyone having the same troubles!
In general, it helps if you make 1 change at a time but you unplugged / plugged SECU and also used OEM key at the same time making it hard to distinguish which one was causing the problem. Since SECU has nothing to do with starting the engine while the key is all about it I'd say it was the key.
Lakersallday24
Jun 16, 2019 01:35 AM
Ray229Harris
Sep 16, 2015 08:16 PM
BobMax
Aug 15, 2015 12:35 PM
laparka66
Aug 6, 2015 09:36 AM
