2002 - SE Stock head unit (non bose) audio fading in/out - TAPE ERR as well
Old Aug 22, 2012 | 08:52 PM
Saadkhan07's Avatar
Title says it all,
I got the stock none bose setup, and 1. my audio will fade in/out sometimes, and also my casette player is turning into ****. It will play the cassette adapter, switch to the other side, and display TAPE ERR and get stuck, and it comes out a bit later.
My audio is also sounding like crap with the tape. I just ordered a tape head cleaner, so i am hoping that fixes it.
Any clues ? someone said it could be the stock amp in the car going out
Old Aug 22, 2012 | 08:59 PM
T_Behr904's Avatar
Originally Posted by Saadkhan07
Title says it all,
Rip that garbage out and get you a good aftermarket HU.
Old Aug 22, 2012 | 09:02 PM
Saadkhan07's Avatar
re
i want to...but i heard if you do change it, then the steering wheel controls get disabled, and so does the MPG/DTE computer.
this true ?
Old Aug 22, 2012 | 09:13 PM
ranmas2004's Avatar
this true ?
They have special adaptors that you can buy to keep steering wheel controls. Get a new HU...factory stuff is trash.....
Old Aug 22, 2012 | 09:15 PM
ViRTualTeRRoRisT's Avatar
this true ?
Yeah, that's the unfortunate truth. I swapped mine with a Pioneer and I personally love it, but the steering controls woulda completed the system all together.
ETA:
This I did not know. Would you mind pointing the audience in the right direction?
Old Aug 24, 2012 | 06:59 AM
djfrestyl's Avatar
Suspension Yoda
ETA:
It's called the Access ASWC. All you need to keep your factory steering wheel controls (as long as the HU you pick is compatible)
Please read the "Bose radio replacement" thread in the audio section.
A LOT of good info in there.
Old Aug 24, 2012 | 11:43 PM
cmd26's Avatar
If you replace your factory hu with an aftermarket the mpg/dte still work, you do lose the trip and volume controls.
Old Aug 25, 2012 | 06:30 AM
djfrestyl's Avatar
Suspension Yoda
WRONG.
Trip controls will work, you have to ground the brown/yellow wire in the secondary harness (applies to 02+ maximas only)
Steering wheel controls can work, you just need the Axxess ASWC interface module.
Old Aug 25, 2012 | 10:00 AM
cmd26's Avatar
WRONG.
Im not wrong I have installed my radio without grounding the brown/yellow wire or a axess aswc interface module I have no trip or volume control but mpg and dte still work.
Old Aug 27, 2012 | 06:02 AM
djfrestyl's Avatar
Suspension Yoda
Sir, you do realize that the REASON your trip controls don't work is because you have not yet grounded that brown wire?
Old Aug 27, 2012 | 07:05 AM
njmaxseltd's Avatar
Isn't this a 1980's issue? I think I used a cassette adapter in my Prelude...
9aj9
Apr 5, 2020 12:11 AM
crazyespn
Sep 3, 2015 01:30 PM
Justin Kroll
Sep 2, 2015 11:06 AM
