2002 Maxima SE Existing Speaker Wiring
Hi All
Just had a new head unit istalled in my car as well as new door speakers. I like the sound but it needs some extra base punch. I have an amp and sub which I can install. The sub would go in trunk.
Its a passive sub so it will run off speasker wires from the amp. My question is if there is any existing speaker wiring running to trunk from the front and where I may find it. Also... Where is the best place to install this small amp?
Steve
Steve
Hi All
Steve
Steve
You mention that you have a sub and amp, but you want to run the sub passively? This makes no sense. Please clarify so we can help.
It's a non Bose sys. My sub has no built in amp but I do have an amp for it. Just wondering how much if any existing wiring can be used to install this sub in trunk and..where would be best location for amp.
Run a proper RCA and remote turn on lead from your aftermarket head unit to your aftermarket amp. Run a proper (and adequately large enough) fused power wire from your battery to your aftermarket amp.
You can locate the amp wherever you want - under a seat, mounted to the back of your rear seats, trunk floor, trunk ceiling. etc.
fastcarny
Aug 12, 2015 03:50 PM
yat70458
Aug 3, 2015 01:16 PM
