Issues with my 03 max se 6 speed
Old Sep 11, 2012 | 10:13 AM
Jacksons_03_se_mt's Avatar
Ive had all 6 ignition coils replaced by nissan the rear valve cover replaced by meineke that I bought from a nissan dealership. Now under accelerion I see white smoke then ses light starts blinking.. Car doesn't overheat. Im smelling burnt oil.. I'm open to all suggestions and advice.. Thanks in advance
Old Sep 11, 2012 | 10:15 AM
MaxinO2's Avatar
Drive to Autozone and get them to scan your system with ODB meter. Find out what code your getting.
Old Sep 11, 2012 | 10:16 AM
MrEous's Avatar
^ Jeff™
Did you check the codes to see if the flashing has left something?
Performance issues?
Are you using a lot of oil?
Left bank piston rings might be gone. (worst case)
Old Sep 11, 2012 | 05:38 PM
nsnrider's Avatar
sounds like you need a motor rebuild due to exsessive oil consumtion and burning. How many miles on the car?
smoke upon start up or only when running?
Old Sep 11, 2012 | 05:56 PM
vfrpilot28's Avatar
Start with the basics, get the SRS codes checked and then search here.....then keep plugging away
Old Oct 7, 2012 | 04:15 PM
as far as performance issues go: at first it was running fine then it slowly got worse nowit wont wont rev past 3k in neutral and 2500 in gear sometimes 1500 it would jerk as if it were hitting the red line.. it burned much more oil before than it does now and the smoke is only if i would go past 5500k and beyond, and after i come to a stop.never noticed any smoke on startup. i had to go to inspection to avoid being ticketed, car failed due to SES light. the code was p0300
Old Oct 7, 2012 | 04:39 PM
BigLou55's Avatar
^^^your code is for multiple misfires. When you changed your coils did you check/change your plugs? Also, you could have a faulty coil from nissan(it does happen)
Old Oct 7, 2012 | 04:48 PM
Itz da AIDz.
Old Oct 7, 2012 | 05:02 PM
VQ30DE-K's Avatar
Yeah its definitely a multiple misfire, if you say that check engine flashes, I wouldn't even drive until problem is fixed.
Old Oct 7, 2012 | 05:49 PM
BigLou55's Avatar
I agree because misfires will ruin a catalytic converter, I have experienced this first hand.
Old Oct 9, 2012 | 05:18 PM
gonna get it checked out Thursday by a tech at Nissan my father takes his 02 gle to. thanks for the input.. ALL was greatly appreciated will update when i go and get her back.. just in case if i need a new motor can i just drop in a vq from an auto..??
Old Oct 17, 2012 | 09:38 PM
Alright got two of the cats replaced powers back but when I really get on it the ses light blinks I let off it goes out and stays on I got it read p0300 is back.. Today when I started her up no light but it still blinks when I "drop the hammer" but goes out and goes away and isn't on anymore ..confused
Old Oct 18, 2012 | 12:04 AM
ViRTualTeRRoRisT's Avatar
Wow, same thing actually happened to me. I replaced valve covers, gaskets, plugs and Y-pipe with a warpspeed. 3 weeks later, engine is smoking and doesn't have much power. I got some advice from some mechanics and other peepz, and came to the conclusion that my piston rings are fried and that I also possibly have a blown head gasket.
When the SES blinks, there are multiple misfires (P0300) and ****'s getting wild inside the engine.
Rebuilding the engine will not be worth it. Your best bet at this point is to get another engine, replace it with this one and before you drop it in the car, gut all the cats so that this sort of problem has a less chance of occurring in the future.
I'm currently dealing with this issue and don't have any means of pulling my engine out to work on it. I'd rather rebuild mine on my own, but I don't have much money nor do I have the equipment to do so.
Found it kinda interesting that you're dealing with the same issue with the same car (mine is also an 03 6mt) and that you live in the same city that I do. Weird.
Last thing you wanna do at this point is drive it and damage the block anymore than it already is.
Old Oct 18, 2012 | 08:50 AM
ATL's Avatar
ATL
^^^ i wouldnt assume he needs a motor bc u think you do, out of curiousity, how many miles are on your car?
Old Oct 18, 2012 | 10:31 AM
Well if he takes his spark plugs out for inspection and if there's burnt oil on them, that concludes fried piston rings.
Mine is at 169k.
Old Oct 19, 2012 | 04:15 PM
nsnrider's Avatar
why are you still driving your car if you changed your cats but did not fix your misfire? You will only ruin your new cats. Fix the misfire issue asap. Did you check your ecu for damage? A bad coil can damage the computer.
Old Oct 21, 2012 | 09:08 AM
MaxSoRytVQ30's Avatar
check MAF sensor
I am really surprised no one has seemed to think of his Mass Air Flow sensor needs cleaning or replaced. I can garuntee you the problem you are having is coming from a dirty or faulty MAF sensor. I have been through this issue and seen this issue time and time again. I am no guru but I've been dealing with the Max game for quite a while now and I manage a NAPA in SE Alabama. There is a product you can buy, it may need to be ordered but its manufactured by "CRC" and its called "mass air flow cleaner". 100% worth the $5 shot. Remove your maf sensor from the intake tube spray it quite a bit from all angles let dry ten minutes and try it. If that does not work 100% than you will need to call the dealer provide them with the VIN# and get the correct MAF sensor part # required for your car. Not sure abut the 03 model but I do know my 02 could use 3 different ones but only one operates properly. Once you get the dealer part # call Napa or any parts store and have them interchange that # and get it. If you can afford the $600 dealer part get it if not you can get a after market for around $200 depending on your specific one required. I can garuntee you will have your car back running just fine especially if you replaced coils and don't hear any rod knock. If you don't repair this problem pretty fast you will stop up your cat with all the smoke and mess up the exhaust valves. Then my friend you have a real issue! Try this in these steps and you will have another org member smile on your face as you punish them ricer kids Honda's etc. Hope this helps, well I know it helps just hope you try. Have a good news and let us know how this does for you and your 03.
vingodine
45
May 21, 2016 12:46 PM
02PearlSE
Oct 7, 2015 02:12 AM
JoeWhit
Sep 20, 2015 08:01 PM
paulpearl
Sep 2, 2015 07:50 AM
RealityCheck
Aug 5, 2015 06:18 AM
