Radio Display
Old Sep 23, 2012 | 05:47 PM
MarkVD4's Avatar
Radio Display
Well i recently got my 5.5 gen Maxima and did some body work to it due to the fact that i was rear ended with it. While i had it in the body shop i had the Stillen front and rear lip added to give it a better look. My next idea was to do the fog light rewire to the park lights. That came out looking really nice. The next thing i wanted to do was upgrade my audio. My car didn't come with the Bose system so i bought 4 Rockford Fosgate Primes to swap out into the door and an Amp Interface Kit to add a amp for some subs. For now im using the factory head unit but plan to upgrade to a double din. So today i ran all my wires to the trunk and connected my subs, rcas, all the correct wires. everything works fine but i found when i turn the headlights to the on position the display on the Radio goes away. Once the headlights are switched off the display comes back. I tried turning the headlight to the on position and play with the dimmer switch but nothing happened. What could it possibly be?
Old Sep 24, 2012 | 11:54 AM
TallTom's Avatar
You probably need to disconnect the illumination dimmer wire. I'm not 100% sure since I'm rocking a factory radio, but that is where I would start.
http://maxima.theowensfamily.com/audiowiring.asp
Old Sep 25, 2012 | 07:29 AM
djfrestyl's Avatar
Suspension Yoda
Correct. Disconnect the negative dimmer wire (orange with black stripe). Make sure the illumination wire (solid orange) remains connect.
Old Sep 25, 2012 | 09:40 AM
nismopc's Avatar
Old Sep 25, 2012 | 10:13 AM
djfrestyl's Avatar
Suspension Yoda
Jeez - nice catch.
Something was messed with behind the radio. Need to know exactly what was done - more specific than "RCA's and correct wires."
Old Sep 26, 2012 | 07:08 AM
MarkVD4's Avatar
I fixed the problem. The harness i bought was missing one end of the dimmer switch wire. All i did was tap into the Dimmer Switch wire from the factory harness and connected it to the orange and black wire on the aftermarket harness.
gavin68
Sep 18, 2021 12:36 PM
chisam14
Nov 6, 2018 08:56 PM
wiseguy6199
18
Oct 1, 2015 12:28 AM
Max Nu-BE
Sep 28, 2015 10:25 AM
