Need help with VQ35 swap
Old Oct 6, 2012 | 04:07 PM
tosheto's Avatar
I just purchased 02 Maxima SE 6 speed. The problem is that the previous owner broke the water pump, overheated the engine and as a result the head gasket is blown and one of the connection rods broke. I am going to pull the engine out and swap another one in. My questions are:
1. Where can I find an engine?
2. What engine should I buy?
I have done a good amount of research and it seems like the best thing to do is get 05-06 maxima/altima/quest engine.
I want to buy lower miles engine and avoid the oil burning issues of early vq35s. I am going to daily drive the car, so I am looking for relatively cheap engine that required little modification to go in the maxima. If I need to swap oil pans and intake it will be fine, but I want to keep things simple. Any help and input are appreciated.
Old Oct 10, 2012 | 06:40 PM
Max streets's Avatar
junk yards,lkq i brought 1 about two months ago 4 1000$ off a 07 with 47k for my 96 swap.
Old Oct 11, 2012 | 08:27 AM
tosheto's Avatar
I will look them up. Thanks for your reply.
Old Oct 14, 2012 | 08:59 PM
tosheto's Avatar
Anyone else wants to offer input. I have a shop that will do the swap. I just need to get an engine. I have been thinking of getting either 05 or 06 maxima engine. Just so I can keep things simple. Let me know what you guys think.
Old Oct 14, 2012 | 09:38 PM
AznRyan's Avatar
Someone listed a link that had VQ35's going for $500-$700 a piece, if you look around I'm sure you can find a cheaper one than a grand. Have you tried using the searchbar?
Good luck on your engine swap!
Old Oct 15, 2012 | 10:54 AM
tosheto's Avatar
Care to tell me how to find that link? Yes, I have used the search bar.
Old Oct 15, 2012 | 10:56 AM
AznRyan's Avatar
I'll look around, see if I can find it
Old Oct 15, 2012 | 11:00 AM
yes thiers islandmax parting out his 3.5swap motor already done just have to drop it in
Old Oct 15, 2012 | 11:04 AM
AznRyan's Avatar
I found some on car-part.com, some in the 2 grand range, some in the couple hundred range. Didn't look in depth, but they're there.
Old Oct 15, 2012 | 12:18 PM
VQ'rInWLA's Avatar
04+ should be the range of 3.5's that youre looking at.
Old Oct 15, 2012 | 10:14 PM
tosheto's Avatar
Thank guys. I am thinking of getting 05-06 maxima engine just to keep things simple. I have been checking car-part.com regularly. Just want to keep my options open. If anyone has any other ideas or input for an engine or where to purchase from let me know. Thanks
Old Oct 16, 2012 | 02:51 AM
TurboA32's Avatar
I think you should do the 5.7 gen swap
Old Oct 16, 2012 | 08:32 AM
tosheto's Avatar
Damn man. Don't give me bad ideas. 02 6 speed with 290HP at the flywheel
Old Oct 22, 2012 | 01:35 AM
tosheto's Avatar
Any other ideas/input/suggestions?
Old Oct 22, 2012 | 02:10 AM
VQ'rInWLA's Avatar
I have a set of Cometic headgaskets for sale BNIB that you can use for your swap.
Old Oct 22, 2012 | 10:13 PM
tosheto's Avatar
I am planning on buying the engine and dropping it in, so I do not think I will need the head gaskets, but thanks.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
mclasser
22
Nov 12, 2020 01:58 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
