VAFC2 with LRMAF/BBMAF
Old Oct 14, 2012 | 03:31 PM
nishfish871's Avatar
I am about to install the LRMAF on my car. Was seeing if you guys used the IN/OUT settings or just altered the Hvt while using the 1/1 IN/OUT setting.
Also how do you adjust the idle AFR because I connected the LRMAF and my wideband read something crazy like 20 AFR at idle; shut the car off asap when I saw that. Would it self adjust to around 14.7 on its own?
Waiting for Nmex to chime in...
Old Oct 14, 2012 | 05:23 PM
carsnwomen91's Avatar
Help me too please! I wanted to do this but I thought you need safc for maf scaling...
Idle afr is adjusted in the narrow throttle setting at 1000rpm.
Old Oct 14, 2012 | 06:39 PM
Thanks, that gave me the courage to try it again just now.
This actually helped me create a baseline. These settings are working, a lil on the rich side at partial throttle. I haven't messed with 70% or higher throttle yet.
http://forums.maxima.org/8052062-post24.html
Old Oct 17, 2012 | 09:33 AM
Nice find, would it be the same with z32 maf?
I think the 3k rpm switch over is a bit high :S even for the 3:5
Wow lots of correction to low throttle but why are there 3 corrections 3100 and above? Wouldn't it be two? Like narrow throttle hvt (for corrections at part throttle <20%, open vi from 3100rpm-redline) and wide hvt (open vi, open throttle >70% 3100rpm - redline)?
Old Oct 17, 2012 | 09:41 AM
There's also a correction setting for between lvt and hvt, I don't remember what its called atm but I'd set it to 0... I believe its to add/subtract fuel in open loop just between lvt and.hvt
Old Oct 17, 2012 | 09:58 AM
It's called vtec unmatch and.its on-top, additional corrections between the old vtec.point and the new.vtec.point (not seen by the ecu) so we don't need that.
What are the in/out settings for? I have the PDF vafc2 manual but it doesn't describe the function, only shows how to adjust :/
Old Oct 17, 2012 | 10:18 AM
Found streetlegendz's thread but no one helped him.. http://forums.maxima.org/supercharge...-settings.html
I think 6/6 was good for him but he didn't add narrow throttle corrections, that's why his car seemed retarded when he revved it.
Old Oct 18, 2012 | 02:29 AM
CMax03's Avatar
search ! But I remember NMex using in/out reading for that of a Q45 in/Oem out IIRC...it's a numeric value.....
t6378tp
Aug 24, 2015 07:03 AM
tibal
Nov 10, 2011 05:57 AM
VQ'ed
Feb 21, 2010 05:18 PM
MaxSoRytVQ30
Nov 3, 2007 08:25 PM
d00df00d
May 24, 2006 08:33 PM
