Engine revs REAL high at startup
Old Oct 22, 2012 | 08:05 AM
Montego Murph's Avatar
Hey all,
I've got a 2001 I30.
I've noticed that right after I start the engine (especially when cold,) the engine will rev to 3-4000rpm for a brief second as soon as the engine starts.
This CANNOT be good for the engine -- a half-throttle blast before oil pressure is built up on a cold engine?
Is this normal, and if not, how do I get this under control?
I should add that I did try to search for this before posting, but couldn't find anything relevant withe the search terms I chose, and I wasn't exactly sure how to phrase it.
Old Oct 22, 2012 | 10:26 AM
BigLou55's Avatar
you mean as soon as you turn the key and the car starts it revs up to 3-4k for a split second and them back to 1.2k(maybe higher) or so if its cold? Dude that is normal. I haven't started a car that did not do that at startup.
As long as it immediately goes down after startup your fine.
Old Oct 22, 2012 | 10:36 AM
Lou -- Yes, exactly that. Odd, in all the cars (25ish) I've never experienced that.
Old Oct 22, 2012 | 10:41 AM
Jeffc21's Avatar
Mine does the same thing . I thought it was kind of a high rev too. I don't quite know what to think ????
Old Oct 22, 2012 | 10:46 AM
BigLou55's Avatar
different makes will rev differently at start up but the maxima is a high rev'er upon start up(especially cold). It doesn't go as high when the car is at operating temp and started.
Old Oct 22, 2012 | 11:29 AM
Shift_A32B's Avatar
That's normal only if the rpms go down on a split second. If it stays in high rpms, such as 3-4k, then its not normal.
Old Oct 22, 2012 | 01:02 PM
DjHackStyle's Avatar
My old jetta started up at 900rpms after 2 weeks being off in freezing temps, not normal?
I always that my maxima reved high aswell but it doesnt go that high its usually 1.2krpms
Maxima.KsA
May 15, 2020 04:14 PM
nbstriker10
Sep 4, 2015 04:26 PM
TheMafia
Sep 4, 2015 08:26 AM
dcardello
Sep 3, 2015 11:44 PM
Justin Kroll
Sep 2, 2015 11:06 AM
