added led lights under door handles
2002 maxima (my wht gurl) i added led lights under all 4 door handles and under front and passanger floor boards. no short cuts ran evrything through doors no wires showin stickin out. nice and clean. lights hooked to the dome lights. come on when doors r open and when remote start comes on then goes out. ![added led lights under door handles-sam_0205.jpg](https://maxima.org/forums/attachments/5th-generation-maxima-2000-2003/2829d1482451085t-added-led-lights-under-door-handles-sam_0205.jpg)
![added led lights under door handles-sam_0206.jpg](https://maxima.org/forums/attachments/5th-generation-maxima-2000-2003/2830d1482451085t-added-led-lights-under-door-handles-sam_0206.jpg)
![added led lights under door handles-sam_0207.jpg](https://maxima.org/forums/attachments/5th-generation-maxima-2000-2003/2831d1482451085t-added-led-lights-under-door-handles-sam_0207.jpg)
![added led lights under door handles-sam_0208.jpg](https://maxima.org/forums/attachments/5th-generation-maxima-2000-2003/2832d1482451085t-added-led-lights-under-door-handles-sam_0208.jpg)
![added led lights under door handles-sam_0209.jpg](https://maxima.org/forums/attachments/5th-generation-maxima-2000-2003/2833d1482451085t-added-led-lights-under-door-handles-sam_0209.jpg)
Can You Please Post The Steps Ive Been Wanting To Do This Just Scared To Approach It Wrong. It Would Be Greatly Appreciated. Looks Nice By The Way. I Was Going To Do The Blue Lights On My White Max
Good work OP. I did this last year on maxima, I'll post pictures later. I offered it as a service on nycmaximas for a short period of time but because it was so labor intensive and tedious I stopped, wasn't worth the money. I did about 3 maximas.
To those interested in doing it, my method was running the positive and negative wires into each door, tapped into whichever source you wanted. I personally preferred the dome light so it faded on/off and came on when you unlocked. I had a customers who preferred them to be on with the parking lights. Blue leds on a white maxima is a nice combo.
As far as routing to the door handle, I ran the wire outside of the path of the window. Then each door handle already has a hole in it to allow thin wires to pass through. I hot glued an led in the corner under the door handle and put a dab on the side which routed it back into the car.
Not sure how the OP chose to do his. I miss this about my old maxima so much.
trasmadean
01-20-2018 05:05 AM
vingodine
45
05-21-2016 12:46 PM
220k+ A32
08-17-2015 03:57 PM
