2002 Maxima Engine Tick
Old Nov 7, 2012 | 04:20 PM
jlgwinn's Avatar
Ladys, Gentlemen...
Just a question question if you will. Please take it easy on me as this is my first posting. I just purchased a 02 Maxima with a engine tick. It sounds like a lifter has collapsed, but reading here, I see that they have a solid lifter. The car has 186k, the noise is constant and changes tune with engine speed. As the rpm goes up, the noise gets faster. The noise starts right off the bat when the car is started and doesn't stop until the car is cut off. The noise sounds like it's coming from the middle of the rear bank. I've used the screw driver to try to pin point the ticking by placing it on the injector and fuel dampers. To my surprise, there's no ticking coming from either component. So, with that being said, any simple suggestions that I can check or start pulling it apart checking valve clearance? I've included a video for your viewing and listening pleasures. Any help would be truely appreciated..
Oh, oil is full and clean..
http://youtu.be/TibFla6tSsQ
Jeff
Old Nov 7, 2012 | 04:27 PM
rjfoste12's Avatar
how loud is it? mine does the same thing,but it does have 220k lol. Could be your pcv valve as well if its not too loud.
Old Nov 7, 2012 | 06:35 PM
jlgwinn's Avatar
Check out the youtube link.
Old Nov 7, 2012 | 07:59 PM
T_Behr904's Avatar
Get a bottle of this. It's available as just about any auto parts store. Report back on if it helps. I've used it on several cars over the years and it's always worked for me.
Old Nov 7, 2012 | 08:08 PM
Maxx6spd's Avatar
would a low octaine gas cause this?
Old Nov 7, 2012 | 08:16 PM
jlgwinn's Avatar
Will do...
Old Nov 7, 2012 | 08:18 PM
jlgwinn's Avatar
Only premium has been run through the engine since 39k. Well, that's what I'm being told.
Old Nov 7, 2012 | 08:21 PM
Rods03Max619's Avatar
Yeah that **** is Loud, good Luck hope you figure the problem out....
Old Nov 7, 2012 | 08:22 PM
Will do...
Hope it works.....
Old Dec 13, 2012 | 04:07 PM
jlgwinn's Avatar
Hey guys, me again...So I tried the CD-2 with no resolve to my engine tick. I ran that for 300(+-) a few miles. I decided to take off the rear valve cover to check valve clearance this weekend on the rear bank. All was picture perfect with the exception of the #5 exhaust clearance. This guy was about .030 or so that I'm going to guess. My feelers only went up to .024 so I'm just guessing. I started to take feelers apart to get a more accurate picture but this was good enough for me.
So, with that being said I thought I had a option. I've read in a few places that the shim could be changed. NOT! This isn't the case as the whole bucket will need to be replaced. Is there any secrets to changing this besides pulling the front cover, then the camshaft? I would say no, but coming to the gurus for expert advice.
Jeff
Old Dec 13, 2012 | 06:37 PM
carsnwomen91's Avatar
Jeff
prob a money grabbing thing... on my ninja 250 i had a nut and bolt for adjusting the valves soo easy! then i got into a zx7r and they had shims like every other bigger bike.
Old May 8, 2013 | 10:40 PM
kalvina's Avatar
Dude My car is doing the exact same thing!!!!
Here is the link to my post.
http://forums.maxima.org/5th-generat...-included.html
Its driving me nutz as well. Were you able to find a solution to this problem? I read on your youtube video, someone said that it would cost 2k to fix it. I hope this is not the case. I have poured mystery oil and have been running it for the past 300 miles and nothing... Let me bro. THanks
fastcarny
May 18, 2020 10:40 AM
fastcarny
Aug 12, 2015 03:50 PM
papo99
Aug 9, 2015 07:24 AM
yat70458
Aug 3, 2015 01:16 PM
