P0300 Solutions?
Old Nov 11, 2012 | 01:57 PM
rawrbarz's Avatar
P0300 Solutions?
I've been struggling to find a solution to the P0300 "Random Misfire" code for awhile now. I've changed the plugs, coils, UIM gasket, and PCV valve/tubing to no avail.
Has anyone came across this code? If so what did the problem end up being?
Old Nov 11, 2012 | 05:26 PM
TunerMaxima3000's Avatar
Vacuum leak is the most likely cause of this issue.
Followed by MAFS and Coils.
First test is a Vacuum leak check.
Second is check for exhaust leaks.
3rd is monitor Fuel delta (Fuel trims)
Old Nov 11, 2012 | 08:49 PM
nsnrider's Avatar
i've had a random misfiring code. i also swapped out a coils, plugs, gasket and maf and the misfire still came back and engine misfiring too. only one code registered and never pointed to any individual cylinder, turned out to be a bad engine computer due to the previous coil burning and shorting out the ecu. I swapped out the ecu and problem went away.
doctorpullit
Apr 23, 2017 05:35 AM
homewrecker
Sep 23, 2015 03:41 AM
jchronis2552
Sep 21, 2015 05:52 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
maximusrising
Sep 4, 2015 06:31 PM
