Timing chains
Old Nov 18, 2012 | 09:51 PM
savier's Avatar
Timing chains
ok, so im new to the site but a nissan enthusiast , so i have a 01 maxima with a engine reaching 200k, my timing chains been rattling for a while now but 2 nights ago when i raced my friend and took my car too 115mph ( which was the first time i did due to the miles my engine has) it ran like a champ!!! but every morning since that night, my chain hasnt been rattling like it did when i would start it up, anyone has an explination?
did me riding the ***** out of my engine fix the tension on my chain
Old Nov 18, 2012 | 10:17 PM
Aviation005's Avatar
prob burnt out sludge and it allows it to be lubricated better. start using synthetic oil, always keep an eye on it. timing chain is never cheap.. $1000 minimum for us 5th gen guys
Old Nov 19, 2012 | 07:23 PM
savier's Avatar
hmmm never thought about that, sounds possible, thanks!!!, i mean i did seafoam my engine by sucking the seafoam into my cylinders via the brake booster hose, idk ima keep an eye out but about the oil, i herd its not good to use synthetic on oil motors, im accually about to experiment using part synthetic, so ill let you know how that goes
Old Nov 19, 2012 | 08:50 PM
kurbin's Avatar
Synthetic oil is okay to use, but its pure, and can clean away dirt in the engine that is blocking what could be a potential leak. If your going to use synthetic, its best to use it from day one, or when the km's are still low. Why are you going to a semi-synthetic?
Old Nov 19, 2012 | 09:22 PM
rebelhell's Avatar
I bought my car with 120,000 miles on it. I have no idea what was used before me but I've been using Mobile One pure synthetic extended life since then. I now have 151,000 miles and the engine doesn't leak a drop and as far as I can tell has near zero oil consumption. From what I hear on this forum that's a rare thing though.
Also (and this is second hand so don't quote me), it does no good to use a synthetic blend. Synthetic is designed to not break down as fast under the conditions that break down conventional oil (heat, moisture, air). When mixed with conventional oil the conventional oil in the blend breaks down just as fast as it would on its own, thus contaminating the synthetic that you paid a premium for. It doesn't hurt but it doesn't help either and is just a waste of money. I'd go full synthetic or stay with conventional. Don't waste money on "blends".
Old Nov 19, 2012 | 11:38 PM
kurbin's Avatar
yeah! if it works, stick with it
Old Nov 21, 2012 | 04:36 AM
savier's Avatar
im using castrol GTX because i heard its one of the best for my engine but i also use lucas oil stabilizer mixed in, i mean what your saying does make sense but i never leave my oil in for more then 2500, so maybe i should just stick to conventional, i just wanted to try the syn blend to see how it works
Old Nov 21, 2012 | 08:42 AM
rebelhell's Avatar
There's nothing wrong with Castrol GTX. I'm not saying you have to use synthetic or you're neglecting your car. I just don't think mixing the two is a worth the trouble. Don't know much about Lucas Oil Stabilizer though. Like I said I'm no expert. 2500 mile oil changes seem a bit excessive though. I think Nissan recommends 5000 miles right? I usually change mine between 5-7000 and that's probably overkill for synthetic. Of course I put that many miles on in two months and it really depends on how you drive too. I've spent hours researching oil on the net and the only thing I've learned is everyone's an expert and everyone has conflicting opinions. You are certainly not hurting your car at all I'm sure.
edit: I have just requested a test kit from Blackstone Labs. Going to run my oil to 10,000 and send it to them. See how well it holds up.
Old Nov 22, 2012 | 05:30 AM
savier's Avatar
nice!!! please let me know about the results, but lol yea that could be true about everyone knowing bout oil, thanks everyone for your input but ima just run with the part synthetic and see how my engine talks back to me about it
Old Nov 22, 2012 | 12:45 PM
mau108's Avatar
Forget about lucas, that stuff useless.
Switch to Pennzoil Yellow bottle (if you want to stick with regular oil). It has better additives then some synthetic oil!
If you want to go synthetic give Pennzoil Ultra 5w30 a try.
These oils are what I use in all my vehicles and have seen first hand how they clean up the motor and keep internals looking clean.
Old Nov 22, 2012 | 06:50 PM
MaxFiyah's Avatar
cause it likes to be driven hard jk lol
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
