engine for my 2003
Old Nov 20, 2012 | 05:00 PM
stevedookie's Avatar
engine for my 2003
Hello everyone. I have a 2003 maxima, I know they have some problems cause I blew my engine. Well my question is is the 3.5 engine that is from 2004 to present compatiable to my 2003. Meaning all I have to switch the oil pans and throttle body and could I use the 2003 harness.
Thank you. Steve Dookie.
Old Nov 20, 2012 | 05:15 PM
MrEous's Avatar
^ Jeff™
Well Mr Dookie, the engine from newer years IS compatible. I suggest you research a little on the subject.
My immediate thought is the 6th gen (04-06?) is most compatible. Don't leave out Quest VQ engines either.
Good luck, Mr Dookie...
-Jeff
Old Nov 20, 2012 | 06:02 PM
tosheto's Avatar
^ what he said. Many FWD VQ35s will work, The easiest one will be 04-06 Maxima engine. I just got 05 VQ that I am prepping to put in my 02 6 speed
Old Nov 21, 2012 | 03:05 PM
nsnrider's Avatar
yes, swap out the upper and lower oil pans, swap out he intake manifold upper and lower and fuel rail and the rest of accessories (i.e. alternator, etc.).
you can use original harness.
Old Nov 21, 2012 | 05:14 PM
LazYRaCeR's Avatar
Maybe even see if you can find a VQ35DE from a 09+ Maxima that was hit from the rear or something.. 290 hp stock!
Old Nov 22, 2012 | 05:51 AM
Thank you very much guys. Will be in the works of it in a few weeks. I wil let you guys know how it went.
Thank you very much enjoy your thanksgiving and be safe.
Steve Dookie
Old Nov 22, 2012 | 09:05 AM
tosheto's Avatar
09+ will take a lot of modding to fit. There is a thread about that on here
Old Aug 16, 2013 | 02:31 PM
well guys I got the 06 engine, put it in . swapped the oil pan on the 06 to a 2003 cps not fitting called back couryesy nissan and found out the one I ordered was for a automatic. so I ordered the other oil pan from great neck nissan will install hopefully all goes well.
shilov
Feb 19, 2024 09:40 PM
Max139617
Oct 19, 2016 11:34 AM
Maximan190
Dec 16, 2015 06:01 AM
iamute
Sep 20, 2015 05:22 PM
seesole
Sep 14, 2015 12:38 PM
